Arct1k's 2011 Berg...
Arct1k's 2011 Berg... - 05.19.2011, 10:25 PM
I suspect this won't be the end of it but here's it so far...
Changes from last season:
-66Bronco tubes front and rear with 86Jeep style steering
-D-Lux Knuckle weights
-VP DH2s in front with 585s and SLW with 350s
-Mann 3rd and 4th Gears F&R
-RC Bros 7075 lockers
-4PL & Dual Micro Pros
05.19.2011, 10:26 PM
But then I got bored.... so on with the changes...
Picked up some CF and the dremel and made a new Carbon T1E SS... With all hardware panels and rod ends its 3.5 Oz...
Motors are getting some attention care of me Holmes and trying something new on the lower links...
Fingers crossed the last couple of bits arrive on Sat...
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
05.19.2011, 10:29 PM
Lookin' good Arct1k. The CF chassis will help the CG a lot. One of these days I need to pull out my Berg and give it a tune-up.
Edit: Actually, what material was it before? I assumed it was aluminum, but it looks like acetal or some other plastic... The effect on CG probably wont be huge, if it has an effect at all. The chassis will be stiffer, though. Is that better for articulation?
Aussie Nerd
05.19.2011, 11:17 PM
Very nice job on the CF chassis, it looks factory! Your whole rig looks very clean and well set out, looks like it would do well on the rocks. Good on you for not jumping ship to the VP10 like all the other sheep.
What's_Nitro most chassis are made of 1/8th delrin now days with the T1e being no exception.
I look forward to progress.
Kieren
05.20.2011, 08:20 AM
Old chassis was re-made by me to - CF lower section with a delrin topper.
mothman
05.20.2011, 04:44 AM
How did you actually cut the CF with just a dremel? It looks really clean!
05.20.2011, 08:18 AM
Just used a marker to trace the outline.
Rough cut with a cutting disk.
Then sandwich both sides of the chassis with one of the orginal side pieces and used a small sanding drum to finish the outline.
Its all by hand and took about 90 mins start to finish.
rootar
rootar's Avatar
05.21.2011, 01:59 AM
Nice choice of motors! One of these days i'll meet up with ya at one of the bigger comps, i was at Midwest, you were at ecc, maybe nationals?
05.21.2011, 08:03 PM
The titanium lower links i bought did not pan out so went with stock T1E... Its ready for its first comp outing tomorrow...
The Holmes 20T's feel great - low speed is fantastic.
