Lowered Carbon LST 2
Big House
Big House's Avatar
Lowered Carbon LST 2 - 06.19.2014, 10:51 PM
I needed a way to keep my LST2 from flipping over on the turn so I took a lesson from racing and lowered the COG. I took some scrap carbon and built, for all intents and purposes, drop blocks and raised the front and rear mounts 12mm or so. In the DMV area so, the first dry day, I plan to see how much better it runs.
Name:	Carbon LST2 before.jpg
ID:	10764   Click image for larger version
Name:	Drop blocks.jpg
ID:	10765   Click image for larger version
Name:	Carbon LST2 after.jpg
CF Ofna DM-1 Pro CC1717
CF Sportswerks Mayhem ST
CF Losi LST2
1/5th scale TC wheels on LSTII
Big House
Big House's Avatar
1/5th scale TC wheels on LSTII - 07.21.2014, 10:29 PM
I took the transformation of my CF LST II one step further by removing the off-road wheel and tire set and replaced them with a set of Delta Plastik 1/5th scale touring car wheels. Using the FG 18mm square wheel adapters, the wheels went on with out a hitch. Finding a screw to hold them on was key, but Lowes can through. Performance note, once the wheels are heated, they stick very well.
Name:	Wheel adapters.jpg
ID:	10769   Click image for larger version
Name:	Delta Plastik wheels.jpg
ID:	10770   Click image for larger version
Name:	LSTII Street top.jpg
Name:	LSTII Street side.jpg
CF Losi LST2
ruudxd
07.26.2014, 11:42 AM
Nice!
Can you make a photo on how you mounted the hexes and wheels?
I am assuming you are using the stock LST2/XXL axles?
Big House
Big House's Avatar
07.26.2014, 04:27 PM
Absolutely. I will post pictures later. But to your question, the adapter takes the place of the hub and the wheel attaches to the adapter via a long M5 screw and washer.
CF Losi LST2
ruudxd
08.26.2014, 08:52 AM
Hmm, so you take of the stock blue hub, and slide on the square FG one?
But how do you secure the FG hub on to the axle?
Can you make some more detailed pics, that would be amazing!
Thanks!
Ruud
08.26.2014, 09:56 AM
Hey Big House, that LST looks great!
Can you measure the tire and tell me how tall it is (diameter)?
Looking for a suitable wheel/tire for my big truck project and those might fit the bill!
Lizard
Lizard's Avatar
08.27.2014, 04:42 PM
Here you can see FG squares mounted to a truggy axle.
http://rcmonster.com/forum/showpost....90&postcount=9
FG wheel adapters
Big House
Big House's Avatar
FG wheel adapters - 08.27.2014, 05:32 PM
Ruud,
Here are the pics of the adapters on the axle. They are connected by two 6mm grub screws that connect to the axle hub. The bore in the adapter is 8mm so they will fit on the axle. Here is the adapter on the truck. I used a bearing as a spacer. This is the wheel I am running as well.
Name:	FG wheel adapter 1.jpg
ID:	10777   Click image for larger version
Name:	Deltaplastik wheel.jpg
CF Losi LST2
Aerodynamic additions
Big House
Big House's Avatar
Aerodynamic additions - 08.27.2014, 05:59 PM
I had a DM-1 parts car laying around and decided to modify the rear diffuser to fit my GTP. My fastest run with it was 102.5. Maybe this will aid in stability and give me a few more MPH. I also added a rear spoiler to my LST2. I cannot wait to run this one. 53 is the best I could get before it went all squirrelly.
Name:	DM-1 rear diffuser.jpg
ID:	10779   Click image for larger version
Name:	DM-1 rear diffuser 2.jpg
ID:	10780   Click image for larger version
Name:	LST2 rear spoiler front.jpg
Name:	LST2 rear spoiler side.jpg
CF Losi LST2
Carbon LST2 wrecked
Big House
Big House's Avatar
Carbon LST2 wrecked - 09.01.2014, 07:12 PM
After a couple of test and tune speed runs in the neighborhood, on the last run of the day, the rear end pushed the monster into a tree and I clipped the rear. Completed separated the rear right side bulk head. Clean break with nothing else broken. I did manage to hit 61.5 mph before the tree ended all my fun. Shooting for mid 70's so back to the lab.
Name:	LST2 GPS speed.jpg
CF Losi LST2
