wheelie bar problems and solution
capitol
wheelie bar problems and solution - 07.27.2006, 09:26 PM
I purchased this wheelie bar. After a while the WB started pushing up against the skid plate. It made far very long wheelies, but was ruining the tires and bending the bulkhead screws.
Next, I used a long screw rod with four tires and it really bent up everything.
Here is the threaded rod used with the four tires. Notice the 2 WB tires :005:
So here is my solution. I used shorter bolts and nuts to secure the WB to the bulks and went with two tires.
Notice I removed the bulkhead braces. Do you guys think this will cause a problem with my hybrid bulkheads?
squeeforever
squeeforever's Avatar
07.27.2006, 09:57 PM
Not with the bulkless. Looks good! What BL setup are you running?
capitol
07.27.2006, 10:09 PM
Im running a 9xl, 9920 esc, 51 spur, 16/18/20t pinions, strobe slipper, single speed tranny, UE 8 spyders and 3300 to 4300Mah 16 cells packs. It rips booty :027: and tears up wheelie bars:D
squeeforever
07.27.2006, 10:31 PM
Lol. Most people don't even run the braces with the bulkless to be honest. So you should be ok.
