E-Maxx brushless RTR weight?
Rtsbasic
RC-Monster England!
Rtsbasic's Avatar
E-Maxx brushless RTR weight? - 08.03.2006, 05:32 PM
I was wondering what sort of weight peoples Emaxx's are RTR including batteries etc. Bit concerned mines a tad overweight.
Mine weighs 5.3kg, or 11.6lbs, with 12 GP3700, 9XL, 9920 controller, UE diffs & cvds, RPM wheels & savage RTR tyres. With 40 series bowties it weighed about the same.
smhertzog
Breaker of all that is Stock
smhertzog's Avatar
08.03.2006, 06:04 PM
I think they are between 10 and 11lbs. If you want to loose weight pull off the shift servo and lock it in high gear or even better get a g-maxx single speed conversion.
Never fight an ugly man..... he has nothing to loose
squeeforever
squeeforever's Avatar
08.03.2006, 06:13 PM
Mine was about 7 3/4lbs.
smhertzog
smhertzog's Avatar
08.03.2006, 07:37 PM
Wow i thought it was more was that without the batteries?
Rtsbasic
RC-Monster England!
Rtsbasic's Avatar
08.03.2006, 06:21 PM
How much weight would I loose by locking into 2nd? Whats the best way to do this without purchasing any other parts?
I can't really think of any ways to reduce the weight on it without sacraficing durability. The only non-essential hopup it has is a wheelie bar, which weighs less than 30g.
smhertzog
smhertzog's Avatar
08.03.2006, 07:43 PM
You'll lose however much your sevo and linkage weigh.
I glued the shaft in place with a little CA glue
Rtsbasic
RC-Monster England!
Rtsbasic's Avatar
08.03.2006, 08:03 PM
If I locked it into 2nd, is it safe to remove any of the tranny gears to take more weight off?
Just had the rear end of my car off, and without the wheels on, it weighs 960g. I swear its the diffs that increased its weight the most.
HotnCold
HotnCold's Avatar
08.03.2006, 09:28 PM
if you want a cheap way to lock the tranny in a gear - use a metal wire from the tranny shaft and secure it to a screw on the tranny. Loosen a screw close to the shaft and tighten the wire on it - then retighten the trans screw. Thats what i did back in the day... Good luck
Hows that "Hope and Change" working out for Ya???
squeeforever
08.03.2006, 10:18 PM
I was I did was take out the shift fork, 1st gear idler, and grind down the 1st speed gear and use it as a spacer to keep the output shaft from sliding and then put 2 screws and locknuts through the 2nd speed gear and shift dog.
Darren
08.04.2006, 07:07 AM
I done that exact wthing with mine too.
My maxx, weighed in at 4.4KG once with Lightning Stadium wheels/tyres. (14 cells, 9xl,)
Creeped its way up to 5KG just now though. :eek: Diet time! Probably all the mud on it :018: .
(Only difference from the pic is that i'm running 4 SuperShocks)
Candyman2
Candyman2's Avatar
08.04.2006, 03:11 AM
RTR with 16 cells, 40 series
5kg thats 11lb's
Nick
COOKIES!
Nick's Avatar
08.04.2006, 04:39 AM
Mine is 11lbs RTR, heres a picture without electrics (would be 16cells, 7xl, 9920):
I need a new tranny though, the one in the picture got badly damaged in probably every way. :(
~ Nick.
Rtsbasic
RC-Monster England!
Rtsbasic's Avatar
08.04.2006, 05:50 AM
Right so now I know its definately overweight. I'll try locking it into 2nd later if I get the time. What other things could I do or parts could I fit to reduce the weight? Thing is I live on a farm and bash it quite hard so fitting an uber-lightweight suspension kit isn't really a good idea.
Attached is a pic of it just after a clean & rebuild.
Serum
Serum's Avatar
08.04.2006, 09:49 AM
Mine is less than 7lbs with a basic XL motor, 3S lipo, stock shell, the singlespeed, gmaxx cf chassis, modified stock 3.3 bulks, dace shocktowers, 4 shocks, integy diffhousings, 7075 cups, stock arms, hpi dirtbonz tires.
With a 4s lipo it should be 7 lbs.
coolhandcountry
coolhandcountry's Avatar
08.04.2006, 10:01 AM
I have a mgt that is 12.5 lbs with 16 cells. I find the tires make a difference. My gmaxx is close to 14lbs. I can loose some serious weight with different tires. I don't worry about weight. Just put more power to make it go.
Peace!
Country
Help support the
Rc-Monster
Buy here
