RRP Slipper
Mike.L
Mike.L's Avatar
RRP Slipper - 09.02.2006, 08:06 PM
hey guys will the Robinson Racing Small Slipper Clutch Plate Traxxas, work on the ofna 51 tooth spure?:013: pic:
  Send a message via MSN to Mike.L
squeeforever
squeeforever's Avatar
09.02.2006, 08:12 PM
Yea, it just requires a few holes to be drilled. It's actually slightly smaller than the spur so be sure to make it lined up.
cemetery gates
09.02.2006, 08:28 PM
yes it works. i just pressed the cluch plate in the spur with the vice and drilled new holes. one thing you will have to do is grind down the original holes to fit the slipper plate on.
squeeforever
09.02.2006, 08:31 PM
Cemetery, I think you have the large one and not the small one.
cemetery gates
09.02.2006, 10:16 PM
i have the small clutch plate, the ones that comes with the 66 spur.
mike, you can see a pic in this thread
http://www.rc-monster.com/forum/showthread.php?t=3923
Mike.L
Mike.L's Avatar
09.02.2006, 09:27 PM
any of you have a picture of it onn?
squeeforever
09.02.2006, 10:20 PM
Thats odd...I coulda swore mine dropped in the 51T spur witha few mm on each side. I could be mistaken though...
cemetery gates
09.02.2006, 10:24 PM
mine was just like .25mm short of just dropping into place so i pressed it in and it was perfectly round too...
Mike.L
Mike.L's Avatar
09.02.2006, 10:26 PM
do you still need the strobe pads or from there you can use the rrp slipper clutch ect... pics anyone???
neweuser
neweuser's Avatar
09.02.2006, 11:32 PM
I don't have pics, but i run the rrp on my girls mostly stock set up and the pads are fine...the reason most people go with the strobe is because the mod 1, the pads, and durability. But the rrp is fine.
squeeforever
09.02.2006, 11:34 PM
You just can't allow any slip...
neweuser
neweuser's Avatar
09.02.2006, 11:51 PM
Make sure it's tight!!!! I;m taking hers off to put the strobe on it, i don't have any pinions that are 32 pitch besides a 16, and it's way tooo much torque! But i have like 4 5mm pinions for her if i use mod 1 with the strobe....so my gearing options are better, especially cuz she's running only 14 cells!
