Pillow Balls, etc
T2693
T2693's Avatar
Pillow Balls, etc - 04.10.2005, 10:18 PM
I was looking around for some pillow balls. RPM has this, Pillow Ball Setscrews & Bushing Caps but I don't think that's the balls just some setscrews and bushings.
Anybody use these or have a recommandation?
I seen the Strobe 7075 Pillow Balls on here so I'm thinking you would need these and maybe the setscrews if you didn't have any to work with, correct?
Any feed back on the Strobe pillow balls would be appreciated.
Thanks
  Send a message via Yahoo to T2693
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
04.11.2005, 12:01 AM
The Strobe pillow balls are probably the lightest pillow balls you can find, as they are aluminum. I also can get (actually, I have some) titanium pillow balls, which are stronger than the stock balls and lighter as well (not as light as the strobes, but stronger). For racing, many will choose the strobe pillow balls, while the bashers would benefit from the titanium.
Superemaxx89
04.11.2005, 12:19 AM
are the strobes lighter than the alum traxxas aftermarket pillow balls
RC-Monster Mike
Site Owner
04.11.2005, 05:53 AM
I couldn't say for sure. I'm sure they are close.
T2693
T2693's Avatar
04.12.2005, 12:18 AM
Would you need something to hold them in place if you didn't have the stock parts?
Superemaxx89
04.12.2005, 12:33 AM
what do you mean? Either thread lock or a set screw can hold a pillow ball in place in an alum arm...i think that what your asking?
sforsancho
empty wallet
sforsancho's Avatar
04.13.2005, 10:29 PM
If you intend to put the strobe pillowball in a aluminum arm, it may not work. The bore diameter is slightly larger than that of stock, so you may get lucky. It's really meant for plastic, where the material can flex slightly. You're best going Traxxas aluminum (weak), UE Titanium (strong), or UE steel (stronger).
If you're really interested in losing weight, you could put UE Ti pivot balls for the front lowers and trx aluminum everywhere else. That's my plan at least.
RC-Monster Mike
Site Owner
04.14.2005, 07:53 AM
I also carry RDLogics Titanium pillow balls, which are a little heavier than the aluminum, but lighter and stronger than stock (and much stronger than the aluminum pivot balls). The Strobes should fit an aluminum suspension arm fine as well.
sforsancho
empty wallet
sforsancho's Avatar
04.14.2005, 12:07 PM
Originally posted by Strobe
My necks are about .02 larger in diameter and a larger radius in the corner
The thread is not tapered but...
They've been tested in the Revo and are doing extremely well. They pretty much conform to all pillowball specs to a degree. The shank diameter is larger and a few other changes. The larger dia had no effect on range of motion in the Revo.
They should install OK for you, watch to make sure they easily thread into the arms if you decide to try them.
I just checked them in a set of Racer-X arms I have and they got pretty tight when threaded all the way in. I would not recommend them in aluminum arms unless you have an easy fit. The minor dia on my threads is slightly larger then specs.
Straight off the UE forums. I'd buy a set but it sounds risky.
RC-Monster Mike
Site Owner
04.14.2005, 02:30 PM
Thanks for the link. I guess I will have to try them myself!
