For all you Tamiya fans
crazyjr
crazyjr's Avatar
For all you Tamiya fans - 02.01.2007, 07:26 PM
Check out the new Tamiya truggy, The Nitrage, pay attention to the tramsmission. http://forums.radiocontrolzone.com/s...d.php?t=233197
jnev
jnev's Avatar
02.01.2007, 08:27 PM
Not exactly a Tamiya fan, but it actually looks decent. Wonder how it wil compare to other larger truggies like the losi muggy.
GorillaMaxx360
GorillaMaxx360's Avatar
02.01.2007, 09:40 PM
look nice but i to am not a tamiya die hard fan
BlackedOutREVO
02.01.2007, 11:35 PM
WTF??? there no pinion on the motro, it goes to a dog bone, and on the motor theres a out drive... thats WIERD... i wonder how that works???
02.02.2007, 12:03 AM
The dogbone goes inside the tranny and is connected to the pinion there...
glassdoctor
TEAM FUSION
glassdoctor's Avatar
02.02.2007, 12:20 AM
That looks cool... would be a killer BL conversion. I think it would be easy to do.... just put a outdrive cup on the motor shaft and strap it down using a *cough* finedesign *cough* style motor mount.
Outdrive Cup
skeeler
Outdrive Cup - 02.20.2007, 11:30 PM
Forgive me, but I'm a newbie to the world of electric conversion. Where can you get the kind of outdrive cup you are talking about? I could imagine using the transmission with the optional 2-speed to build up a 2-speed BL 1/8th buggy.
Note, by the way, that there is a center diff in the tranny. From the press release:
Furthermore, the differential gear on the Nitrage is doubly protected, first by its own durable case and then by a second enclosure formed around it by the front and rear gearboxes.
Also, note that the 2-speed is optional; the Nitrage will run in the truggy class as long as the stock single-speed is kept.
Edit: Here's a photo showing the front and rear brakes, which strongly suggests a center diff:
http://www.radiocontrol.gr/images/tamiya01020713.JPG
revopqrs
uhhh-huh!
revopqrs's Avatar
02.21.2007, 02:07 AM
yikes... look at the servo saver it uses....:010:
crazyjr
crazyjr's Avatar
02.02.2007, 03:36 AM
Need to do something about that cold Glassdoctor
GorillaMaxx360
02.02.2007, 08:58 AM
for all you xray fans check out the xray site and look at there new nitro truggy, buggy, and car. AND yes i am an xray fan
jhautz
jhautz's Avatar
02.02.2007, 07:58 PM
Only problem I see with this is for a BL conversion is changing the gearing. I cant quite tell if you can change the pinion gear inside that transmision.
Very diferent... I'll give em that!!!
to make it...
or break it...
Silent...But Deadly
jnev
jnev's Avatar
02.03.2007, 12:37 AM
Just looked at them after you mentioned they had some new rc's. They look sweet. :004:
glassdoctor
TEAM FUSION
02.02.2007, 08:03 PM
yeah... you would need to get the motor right cause you might have to just swap motors instead of gears. ;)
*cough*
tough to get rid of this dang cold, hee hee
jhautz
jhautz's Avatar
02.02.2007, 08:07 PM
I just noticed that it has a built in slipper clutch on the back of that transmision. You dont see that everyday on a nitro. Now it looks like it was meant to be coverted to Brushless:018:
I wonder if thats a diff inside that transmision.?????? If it is, this is looking more and more like a Tamiya Sliperential that might be adaptable to just about any truggy or buggy.
to make it...
or break it...
Silent...But Deadly
coolhandcountry
coolhandcountry's Avatar
02.02.2007, 08:35 PM
That don't look to shabby.
Peace!
Country
Help support the
Rc-Monster
Buy here
