Balance Flight Powers on Hyperion LBA6
Cartwheels
Balance Flight Powers on Hyperion LBA6 - 02.15.2007, 01:42 AM
Are there any adapter wires that I can buy so that I can balance my Flight Powers on my Hyperion LBA6? If not what is a good balancer that will work for the Flight Powers?
Cartwheels
02.17.2007, 02:28 PM
Ok, since I'm getting no replies I'm guessing there is no adapters you can buy to make a Flight Power pack tap fit onto a LBA6 Balancer. Anybody know a good balancer for Flight Power. I think it has the same tap as the Thunder Power.
02.17.2007, 02:44 PM
If there isn't an available adaptor, you can get the proper connector for each part, cut the other end off, and wire them up together. Mike may have some ideas or even something in stock. Even though he doesn't have tap adaptors listed in the store, he had some that he sent me so I could make my own dual pack Y adaptor.
Cartwheels
02.17.2007, 08:41 PM
Making my own adapter is not a bad idea. I'll have to check into that.
Thanks!
crazyjr
crazyjr's Avatar
02.17.2007, 09:10 PM
Are the metal tips that go in the plugs universal? If so, you could just pull them out of one plug and into the other
Serum
Serum's Avatar
02.18.2007, 04:31 AM
The plugs as used on the flightpowers are pretty standard.
I made my own for the maxamps packs and the graupner balancer (basicly the same balancer)
crazyjr
crazyjr's Avatar
02.18.2007, 07:35 PM
So the Flightpowers are the same as the hyperion?
