wheels turn in opposite directions... :-( please help!
baehan
wheels turn in opposite directions... :-( please help! - 02.23.2007, 09:39 PM
when the front wheels turn forward, the rear wheels turn the opposite direction. what is the problem?
i purchase the FLM front combo bulkhead and is it possible for me to put the gears in backwards? when i assembled everything, it all went together so smoothly. i didn't think anything was wrong until i finished my build and went out for a test. is it possible that i somehow damaged my tranny?
pinolelst
02.23.2007, 09:44 PM
not having that rig I can't say for sure but I think if I put my LST diffs back in upside down they run backwards
hope this helps
Steve
squeeforever
squeeforever's Avatar
02.23.2007, 09:51 PM
All you have to do is flip the front or rear diff. So they won't turn opposite next time, just make sure you install the ring gear on the opposite side from the other.
baehan
02.24.2007, 12:52 AM
dang...i had everything done and now i had to take apart the entire front again. :-( i took apart the front combo bulk and put the gear on the other side and it's working again. thanks for the quick replies guys!
glassdoctor
TEAM FUSION
glassdoctor's Avatar
02.24.2007, 01:09 AM
That makes for a funny-handling truck huh?
:D
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
baehan
02.24.2007, 02:45 AM
i guess this is how you learn about your truck...
Serum
Serum's Avatar
02.24.2007, 03:12 AM
That truck is able to do tractor pulling contests without any other equipment.. Not bad!
