What would YOU do with a Hacker C40-12L?
Aragon
What would YOU do with a Hacker C40-12L? - 04.11.2007, 03:44 PM
Hi all
I have a Hacker C40-12L motor in a heli of mine, but it was a bad choice of motor for the model and I'm at a loss of what to do with it. I'd probably have to sell it for 25% of its original cost in order to compete with existing motors, so I'd rather put it to use than try sell it off.
Well it's a great motor for those that don't know the Hacker C40 series. Heatsinked, sealed, 2500 kv, and probably good for 500-700 watts. I'd like to run it on 4 or 5 cells in a car of some sort. I mostly like buggies, but I think this motor would be overkill for a 2wd 1:10 buggy. Maybe a 4wd 1:10 buggy, but I don't know of any 4wd 1:10 buggies?
What would you do with it? Let me know! :)
meatzardd
#4
04.11.2007, 03:58 PM
team losi has the xxx-4 g+ and mrc academy has there sb series of buggies, these buggies are 4wd electric buggies.
glassdoctor
TEAM FUSION
glassdoctor's Avatar
04.11.2007, 04:03 PM
Would be a nice motor for a 1/10 on 4s lipo.... :027:
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
squeeforever
squeeforever's Avatar
Yokomo probably makes the best, but I would go with MRC's new buggy.
Aragon
04.11.2007, 04:35 PM
These are some really nice buggies. I am a sucker for belt drives. :004:
Squee, which one is MRC's new buggy? They all look good. :D
I really like the Yoki MR-4BXF so far.
Does anyone know what gear ratios these buggies use on their front and rear diffs?
jollyjumper
RC-Monster jumper
jollyjumper's Avatar
04.11.2007, 05:00 PM
ratio is around 2/1~2.5/1,
the bx is 2.2/1 i think, uses a 84T spur 48pitch.
most of the 4wd's are rather tight on space for electronics.
your motor might not even fit if its more then 36mm.
i think it wouldnt work in my 4x4.
also, an sb v2 is a shafty.
real sweet but also shaft drive is the predator x11.
http://www.ttechracing.com/x11/
losi 8ight-t
xray xt8
Sylvester
Sylvester's Avatar
04.11.2007, 05:06 PM
:005: Sorry, i had to post this up;)
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
jollyjumper
RC-Monster jumper
Talking 04.12.2007, 02:59 PM
i did it on purpose.
losi 8ight-t
xray xt8
BP-Revo
BMW M Power!
BP-Revo's Avatar
04.11.2007, 05:08 PM
Crt .5!
Aragon
04.11.2007, 05:11 PM
Thanks. I just found the gear ratios of the 4BX too and it's the same as you say.
Hacker C40-12L is 36mm diameter. It is quite long though at 63mm, but I think I can shoehorn it in just.
Well I've been doing some voltage calculations. Looks like 6S would be better given 10.26:1 final ratio and 2.2" wheels. That would give about 34 MPH. Is that a sane speed for a buggy like this?
It just so happens I have two 3S 2600 packs that should fit the 4BX battery positions. :)
skellyo
skellyo's Avatar
04.11.2007, 05:12 PM
Here's some options:
Tamiya TRF501X
http://www.tamiyausa.com/product/ite...oduct-id=49401
Kyosho Lazer ZX5
http://kyoshoamerica.com/carsandtruc...ars/30076B.asp
Losi XX4
http://www.teamlosi.com/Products/Def...rodID=LOSA0011
Losi XXX4
http://teamlosi.com/Products/Default...rodID=LOSA0015
Yokomo MR-4BX
http://www.yokomousa.com/kits/mr-4bx/index.htm
jhautz
jhautz's Avatar
04.11.2007, 05:21 PM
Convert a HB Lightning Stadium 10. Sower loved his and that would be a killer motor on 4s.
To much power for the belt driven standard electic 1/10 stuff IMO. Stick to somethjing shaft drive with some decent diffs. The electric style ball diffs arent gonna last long either with that kind of power.
to make it...
or break it...
Silent...But Deadly
skellyo
skellyo's Avatar
04.11.2007, 05:29 PM
Or a Lightning GT10, HPI MT2 18SS or HPI MT2 18SS+
jhautz
jhautz's Avatar
04.11.2007, 05:31 PM
GT-10 would be cool!!! Havent seen one of those done yet!!
to make it...
or break it...
Silent...But Deadly
Aragon
04.11.2007, 06:38 PM
Hrm, really? :( That's really disheartening. I love belt drives...
I want to avoid a conversion though. Already got a 1:8 conversion in the pipeline and it's enough of a pain in the butt waiting for components. :)
Will look out for shaft driven kits. The JB4 looks pretty neat, Sylvester. Just looked at the Exploded View of it - looks like it uses Team Associated components... Are the two companies related?
