To anyone with the RC-Monster BL motor moutn
crazyjr
crazyjr's Avatar
To anyone with the RC-Monster BL motor moutn - 05.30.2007, 02:32 PM
Will a Mamba max motor fit in the revo mount? I was thinking if the mount will fit, I could use one for a Jato and do a brushless. I know the mount is set up for the stock motor mount, so it should work. Just need to know if the mamba max motor will fit right. Thanks
Serum
Serum's Avatar
05.30.2007, 02:38 PM
Good point, i've seen this question before; I would say yes, ofcourse.. But perhaps Mike can shine his light on this one.
Perhaps the MM motor is too short to hang over the support, but on the other hand, it's so light; why would it need a support..
Have you looked at the exploded views on the traxxas site to check the motormount? that's one of the first things i would do.
ClodMaxx
hold my beer... watch this...
ClodMaxx's Avatar
05.30.2007, 03:06 PM
i emailed mike a while ago to see if the revo mount would fit the jato...sure would make things easy. i've not heard back from him, but i may try that method. it won't be for a while though...
try it, crazyjr, and let us know how well it works. :005:
edit: here is a jato motor mount (part #5560)
and here is the revo motor mount (#5360)
i don't know enough about either truck to tell if mike's revo motor mount would work...
Eflite Blade 400 heli on 3s
crazyjr
crazyjr's Avatar
05.31.2007, 12:17 AM
I currently have three jato's and was planing to convert one, should it be the single speed or the two speed? probably the single so i can redesign the top plate to work with the saddle lipo's i am going to get to use with it and an HPI RS4mt i am planning to get running. The only thing i am concerned about other than the motor fitting proper on the mount, is the tranny getting in the way. I think i will get one to see, because i got to get an esc plate for my electric revo anyways
thanks guys for the info, I think it will fit well anyways
05.31.2007, 12:43 AM
I would recommend not using the Revo mount in this case. It would cause the motor to sit too high. It is fairly easy to make a mount out of L aluminum and still retain the stock mesh adjustment scheme. And the L bracket is PLENTY strong, especially for a short light motor.
I'm sure you've already seen my Jato conversion, but there is a link in my sig (BL Conversions)...
crazyjr
crazyjr's Avatar
05.31.2007, 12:47 AM
I see you're point, but i admit i'm lazy when it comes to fabrication
ClodMaxx
ClodMaxx's Avatar
05.31.2007, 12:48 AM
and the revo mount is soooo pretty, lol.
i'm sure there's a good reason, but why would the pinion/spur mesh have to be at a parallel angle to the chassis? couldn't it be at a higher angle on the spur?
05.31.2007, 12:55 AM
Well, the higher you put the motor on the spur, the higher the COG. Other than that, I don't think it makes a difference as long as the mesh can be adjusted properly. With the Revo mount, having the motor sit too high will make the mesh impossible since you'll be closer to the top of the spur instead of the side of the spur. You'd have to do some creative modding to get it to work. At that point, might as well go with a L setup IMO...
05.31.2007, 12:52 AM
lol. It should technically work since the Revo mount screws into the actual nitro motor holes, it just would look kinda klunky and not as elegant.
Fabbing the mount really was quite easy (but still took a long time since I use just a dremel). You line it up and drill the holes for the front screws. Then, dremel out straight slots for the rear adjustment. The motor is stationary on the mount and does not change, the whole mount slide back/forth. Although, in retrospect, it might have been easier to simply use a slotted mesh adjustment for the motor itself instead.
crazyjr
crazyjr's Avatar
what BrianG is saying is it will raise the center of gravity, I think and add weight with the mount. I may try it anyways, everytime i try to make something it never works, or if it does, it looks extremely hack
ClodMaxx
ClodMaxx's Avatar
05.31.2007, 12:59 AM
ahhh, i see your point about the slots being too high and the mesh not working.
i guess i'll probably fab something, but that'll push the jato project even further behind. i always buy what i think is the right stuff only to come home and find it's too thick or thin, wrong screw size, etc. and have to run to home depot again. i never get it right the first time, or the first 5, lol.
05.31.2007, 01:02 AM
Fabbing the parts is 75% of the fun of this hobby guys! After all, when else can you use the "dammit tool"? :) (other thread reference)
crazyjr
crazyjr's Avatar
05.31.2007, 01:04 AM
every tool i got becomes a dammit tool in my hands
ClodMaxx
ClodMaxx's Avatar
05.31.2007, 01:07 AM
lol - i'm with crazy. even a simple hammer and nail becomes a dammit tool... or a F tool, with a crushed fingernail to boot...
i have an art degree - so that's my excuse, lol.
supralover72
supralover72's Avatar
05.31.2007, 04:23 PM
^That's not an excuse, you can draw a template, lol.
