Direct to diff outrunner conversion*update*
Direct to diff outrunner conversion*update* - 09.25.2007, 12:02 AM
Copied this from the temp forum. Got bored recently and tried 4s lipo. The truck worked alot better, slight cogging from a standstill, but if I was liberal with the throttle it would take off without problems.
Here is a link to the thread: http://www.rc-monster.com/tempforum/...read.php?t=845
Here is the original post:
Hey guys, just finished my mutant redcat/outrunner truck thingy. It runs great, still playing with the quark settings to get zero cogging from a standstill. I almost have it right. Truck runs well, temps after 10mins were 150 motor, 130 esc and 100 battery. I am running a 5s 2200mah 20c battery. Interestingly enough setting the quark for outrunner does not work as well as the std inrunner setting. I have the torque settings all the way up and the neutral set wide, as the maunual suggests that for cogg prevention.
Differential Ratio: 2.75
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 1
Pinion Tooth Count: 1
Total Voltage: 18.5
Motor KV: 833
Tire Diameter (inches): 3
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0
Spur/Pinion Ratio: 1 : 1
Total Ratio: 2.75 : 1
Tire Circumference (inches): 10.21 inches (259.34mm)
Total Motor Speed: 15410.5 RPM
Vehicle Speed: 54.18 MPH (87.03km/h)
Effective Speed Rate: 2.93mph/V (4.7kmh/V)
Effective KV Value: 833
Motor Torque: Amperage not specified...
Final Torque: Amperage not specified...
Heres the pics, enjoy. Please excuse the zipties
Serum
Serum's Avatar
09.25.2007, 04:40 PM
Love it!
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
09.25.2007, 04:51 PM
That looks great! I am going to try my direct wheel drive outrunner setup some day... wouldn't that be quiet!
Which motor are you using BTW? Have you considered the new Eflite Power xx series motors? They are supposed to be one of the best outrunners available, from what I hear.
Vids?
dabid
09.25.2007, 05:00 PM
Wow, never thought I'd ever see anything like that!
AAngel
09.25.2007, 05:45 PM
We did a direct to diff conversion on a Kyosho Inferno GT with a Neu 1512 1900kv motor. On 5S with 3.9" GRP Rally tires, we clocked it in excess of 90 mph several times.
What is the kv rating of the motor that you are using there?
09.25.2007, 06:29 PM
Motor is a 833kv outrunner, got it cheap off ebay.
Not too familiar with the power output of the various sized outrunners. I would do a lower kv next time, 650kv sounds about right. I would also go bigger, like a 45mm can that is longer, so more torque. This setup has plenty of power, but the truck is very light, so that helps. This is not suited to off road IMO, it works great on road, very smooth with the quark and less drivetrain resistance than with a pinion/spur. Seems to be effecient too, not enough testing yet to be sure though.
zeropointbug
Z-Pinch racer
09.25.2007, 07:31 PM
http://www.greathobbies.com/producti...d_id=EFLM4060A
OR
http://www.greathobbies.com/producti...d_id=EFLM4046A
Those are 50mm cans, and the Power 60 does 1200 watts continuous. It weights the same as an XL motor. 380 grams You can also take the shaft out, and make a custom one, or whatever.
09.25.2007, 09:34 PM
OR
Thanks for the links ZPB (can I call you buggie?)
The 46 size 670 kv looks interesting, The lower kv would let me put larger tires back on it and have more torque for startup. Do you think that the quark 65 would be ablee to handle that motor? Plus I would need to step up to better batteries, I have a pair of 20c 5000 2s lipos to run. And my motor mount would have to be remade to accomodate the larger can size. I will see about finding one of these motors and change up my setup.
zeropointbug
Z-Pinch racer
09.25.2007, 10:57 PM
Call me buggie? lol sure....
I am not sure if the Quark 65 would handle it. What kind of speed would that get you with 670kv? That is what you need to know.
Now I am curious about running one of these in my Revo... I am gonna go do some calcs.
Hickoryhead
RC Wanna BE
Hickoryhead's Avatar
09.27.2007, 01:24 AM
AAngel, I would like to hear more about your conversion. How did you mount it to the transmission? Did you modify the motor or leave it stock? Who is we and do you or they have pictures? What kind temps did you get? What batteries where you running with?
For me I would like to see this all happen. Both outrunner and inrunner. I like seeing new stuff come to pass. There are many people were I live and on this forum that can't afford to build what most of us talk about. They can't spend the kind of money we do on Lehner's, Neu's, Quark's.... I can see a way for others to build what we have at a 3rd of the cost.
Thumbs up to every one commited to this project!!!
zeropointbug
Z-Pinch racer
09.27.2007, 03:25 AM
These Scorpian motors look great, I would like to see the 40mm cans... in my hands.
I am just thinking about how much more space I would have on my Revo if the motor was gone from the engine mount, no tranny, and the outrunner motor was mounted down kinda under the tranny. wow. Get some bullet proof diffs and you are set! Nothing to wear out in the tranny... at least anytime soon.
sikeston34m
sikeston34m's Avatar
Smile 09.27.2007, 07:53 AM
Yes ZPB, that's exactly what I'm thinking of. The motor will set about 60% "submerged" in the chassis. Just enough to make the drive shafts as straight as possible.
RCM has the 4.3:1 diff gears. This will drop the gear ratio to almost equal to an E maxx locked in second gear. If more gear reduction is needed, we can do that with the tire height.
The end result will be alot of lost weight. There will be alot of room opened up on the already tight E-Revo chassis. Alot of wear items eliminated means this thing is going to perform longer and hold up better.
zeropointbug
Z-Pinch racer
09.27.2007, 12:35 PM
The only thing that I am wondering about is the 'spool up' of an outrunner in this configuration... will it have enough 'zap' to make for a pleasant throttle response, you know?
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
09.25.2007, 07:13 PM
That is nice. It should be really efficient. Less weight and less resistance. A bigger can would help. More power and may be better off road performance (?).
pcnutz
pcnutz's Avatar
09.25.2007, 10:28 PM
if that is a 4 pole out runner, see if your esc has 30 degree timming, that should fix your cogging issue
