LSP Conversion...
LSP Conversion... - 01.28.2008, 04:14 PM
coming soon! proposed setup is
Mega aCn 22/30/2F
Quark 80
Flightpower 5s 25c Lipo
Gearing: 15/50
here is the data:
Differential Ratio: 4.3
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 50
Pinion Tooth Count: 15
Total Voltage: 21
Motor KV: 1770
Tire Diameter (inches): 5.7
Tire Ballooning (inches): 0
Motor Current Draw: 70
Motor coil Ω: 0
Spur/Pinion Ratio: 3.33 : 1
Total Ratio: 14.33333 : 1
Tire Circumference (inches): 17.91 inches (454.84mm)
Total Motor Speed: 37170 RPM
Vehicle Speed: 43.98 MPH (70.64km/h)
Effective Speed Rate: 2.09mph/V (3.36kmh/V)
Effective KV Value: 1770
Motor Torque: 0.28 ft-lbs
Final Torque: 3.99 ft-lbs
what do you guys think?
lutach
lutach's Avatar
01.28.2008, 05:27 PM
That will be a nice conversion. The Mega is a nice motor. You can also use lower capacity packs like the 2200 or 2500mAh.
jhautz
jhautz's Avatar
01.28.2008, 05:35 PM
I think it sounds good. I havent tried a Mega motor yet so I'm interested to hear how it goes. I am wondering if the Quark 80 is enough for a truggy though. I have been running one in a 1/8 buggy on 5s with a Neu 1512/2.5d for a while and had no issues at all, but it seems that a truggy would be a little heavier. It just might be OK, but my first instinct is that its a little small and I would look for something a little bigger.
Cant wait to see the build photos.
to make it...
or break it...
Silent...But Deadly
lutach
lutach's Avatar
01.28.2008, 05:42 PM
I forgot to attach a little video I made:
Takedown
WARNING: May become violent.
Takedown's Avatar
01.28.2008, 08:45 PM
Lutach= That Is crazy powerful! I was worried about you using a Shulze ESC since they catch fire until i heard you mention something about it and I laughed. Good luck and happy driving with your setup!
lutach
lutach's Avatar
01.28.2008, 09:19 PM
It's fine with the Mega . The system runs nice and cool. I might be getting the longer ones from Mega. I'm just curious what they can actually do.
Takedown
Takedown's Avatar
01.28.2008, 09:21 PM
Sounds really interesting! Do you think mega is up to par with lehner, hacker and neu?
lutach
lutach's Avatar
01.28.2008, 09:23 PM
I have ran all of te ones mentioned and the Mega is up there with them. I might have a surprise coming in a few weeks though that will sure be added to that class.
01.28.2008, 10:13 PM
You are such a tease Lutach! If you mean a motor, just make sure you have a 12s capable esc with proportional brakes to offer with it! And make sure it is under 150 bucks for the motor/esc!
If you could do that you would be the man!
