Testing big motor on mamba?
magudaman
Testing big motor on mamba? - 02.05.2008, 12:43 AM
I have a 1500w BMC brushless motor coming on thursday and don't have a controller to run it yet. I want to just test the motor out to make sure it rotates and doesn't have a blown coil or anything, since I bought from someone who claimed it was new. So can I use my mamba max at 16.5v to just try and get the motor to spin. It seems it would be fine but just don't want to blow it or anything. Oh here is a picture of the motor for fun:
DrKnow65
DrKnow65's Avatar
02.05.2008, 01:20 AM
MM should take the voltage fine (may have to turn off the LVC in the newest style MM), I think the load would be the question. So long as the motor isn't hooked to anything I would think it would be fine. Is that an in-runner or an outrunner?
magudaman
02.05.2008, 01:33 AM
It is built for electric vehicles. I plan on putting it on a electric off road mountain bike eventually. When I say 1500w, it is supposed to be able to provide a continuous output of 1500w with a far higher output peak. Size comparison is that shaft is 7/8th inch. I plan on eventually pairing it with a Kelly programmable Brushless 200 amp controller and running it at 66v. Should be a lot of fun.
I don't plan on testing it on any load. Guess I will just try it out thursday. I will post the result maybe some more pics. THanks for the help.
johnrobholmes
johnrobholmes's Avatar
02.05.2008, 01:30 AM
It is an inrunner.
It should be fine, just start the motor up slowly and don't put a load on it. Before doing so check the leads for continuity and dead shorts to the case.
thorbinator
02.05.2008, 06:01 AM
electric mountain bike does sound deliciously fun.
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
02.05.2008, 07:29 AM
When you get that motor take a picture with something else in the frame so we can get scale. It really doesn't look that big.
Sammus
Sammus's Avatar
02.05.2008, 07:53 AM
lol i think it looks enormous, that shaft is nearly and inch thick. (I take it that 7/8" measurement is diameter not length?)
magudaman
02.07.2008, 12:42 AM
yah 7/8in is the diameter. I'll get some photos with something to scale it to on Friday. Thanks guys
crazyjr
crazyjr's Avatar
02.07.2008, 02:46 AM
that motor's huge, you can see the shaft is cut for a shear key. Looks like a 1/4 inch key will fit
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
02.07.2008, 03:22 AM
I'm sure it is huge but I am having trouble picturing it OK
02.07.2008, 04:08 AM
You should take a pic of it next to a feigao xl, and put a big read arrow pointing to the xl with a caption. Something like "look carefully and you can see the xl motor hiding in the shadows..."
magudaman
02.13.2008, 04:08 PM
Pulling a Xl motor off would be a nightmare but I put a quarter in there for you.
So I finally got around to taking some photos of the motor this last weekend. This motor is really awesome. Huge 10 gauge wire running inside along with hall sensors and what looks to be a thermo sensor inside too. The full finned unit weighs in at 10.4 lbs, so it not exactly light weight. I also got a chance to run the motor on the mamba max and it works great. It seems to have a lot more poles or something because I couldn’t get it to cog. The peak current I saw at 16 or so volts input was about 10 amps. That was after several full throttle start I felt I didn’t want to push my luck too far and put everything away, but not before taking some more photos for you guys:
That last one is not the actual bike I am going to use but my normal mountain bike. I am hoping to find a bike that with at least 5 or more inches of travel. Thanks for the help guys!
02.13.2008, 04:13 PM
lol, that IS big! Any more specs on it? You mention it's a 1500w motor, and plan to run 66v on it, but what is the KV, max amp load, max rpm, etc? Am looking to do a similar project and am looking at options. Where'd you get it?
johnrobholmes
02.13.2008, 06:50 PM
Dittos. I want to do the same thing. My 3000w outrunner just wont start up under load properly. I need something sensored.
