It would be pretty tough to do on 4s with a MM, more voltage would be better. But finding any tires that would be drivable at that kind of speed may be tough.
i think a set of phaltlines would do the trick.
also, i think you could reach those speeds with a neu 1512 or a 6xl.
The esc can, but I don't think you need an XL motor in the DST. Its 1/10th scale, so you could probably get away with running an "L" size motor of higher kv. On 4s, it could probably do 60mph. You can check out the rcm ext. Crt.5 set-ups and the HB lighting 10 set-ups around here. Those are pretty close to the size and weight of the DST.
