Emaxx Transmission Spur Wobble
Shane_744
Emaxx Transmission Spur Wobble - 02.25.2008, 09:35 PM
I have the Emaxx single speed transmission on a G3R chassis. Converting back to stock emaxx spur, 32pitch pinion etc.
When I tighten down the nylon nut for the slipper clutch it makes the spur gear offset. So when you spin it, you get wobbling action. Way too much for a brushless setup. When you loosen the nut, the spur somewhat "flattens out". I watched the input shaft and it doesn't wobble.
What gives? Anyone know a fix for this other than two washers, one on either side of the nut. Thanks.
"Anyone interested in grabbin' a couple of burgers and hittin' the cemetery?" Royal Tenenbaum
02.25.2008, 09:36 PM
That is common with the stock spring. There is a suitable replacement but can't remember what vehicle it is from.
ssspconcepts
ssspconcepts's Avatar
02.25.2008, 09:40 PM
You could try this:
http://www.rc-monster.com/forum/show...hlight=slipper
I am getting ready to try it on one of my single speed trannies.
Shane_744
02.25.2008, 09:53 PM
Is the spring necessary?
02.25.2008, 09:54 PM
why not buy a sprong? heres one for $40.
http://cgi.ebay.com/VERY-RARE-STROBE...QQcmdZViewItem
Shane_744
02.25.2008, 09:58 PM
I'll sprong it up if I knew where to purchase one. This it?
Urban Dictionary Defintion. Ha
2. sprong
To Unleash the act of setting Angry Geese and other Aquatic Animals Upon Someone
No, really where can I get one?
Shane_744
Sweet. thanks for the link.
02.25.2008, 09:59 PM
they are now discontinued. id snatch this one up and quick!!!
Hickoryhead
RC Wanna BE
Hickoryhead's Avatar
02.25.2008, 10:01 PM
Try this out:
http://www.rc-monster.com/forum/showthread.php?t=9341
Both modifications work great. Cheaper then the real stuff.
NECESSITY IS THE MOTHER OF INVENTION
Emaxx Tranny slipper modification (Strobe like)
Shane_744
02.25.2008, 10:10 PM
BL_RVO
Will that work with the stock emaxx spur? I have the strobe setup but it's limited to 9t pinion and 51t spur (that i know of). And lamo towerhobbies is out of 9t mod1 pinions.
02.26.2008, 11:06 AM
mgt spring does the job - fixed almost all of my wobble - $2 fix
Shane_744
02.26.2008, 11:24 AM
cool. is that the Associated MGT??
wallot
wallot's Avatar
02.26.2008, 11:44 AM
yes associated MGT. but did not work for me that much. I ended up with a bonnet sprong clone with custom preasure plate ($.50 fix)
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
Shane_744
02.26.2008, 12:58 PM
Aight. I just used two flat washers on either side of the spring. It took a couple of tightening and untightenings to get it flat. Works good now.
Now i have to deal with the pinion flying off. Lost one in the yard last night.
02.26.2008, 01:13 PM
Blue threadloc- mans best friend.
