Originally Posted by lincpimp
Sounds like it is time to go to the jato spur gears. They are 32p and much stronger than the 48p gears. Use reguar 32p pinion, like the emaxx ones, or robinson racing sells them too.
Let me know what you current gearing is (pinion and spur) and I will tell you which ones to buy to maintain the same gearing. Plus you can run with the cover off, as the 32p gears do not care about sand or grit. My motor even came loose and cut the teeth half off, readjusted the mesh and I am still running the same spur!
I'm running the stock stampede vxl pinion and spur. I think it's 48p and the spur is 86t. I'm going to go to robinson racing's website to see if they've got the correct spur and pinion I need. any suggestions on sizes?
My pinion must be shot because i keep tearing up spurs (2 per afternoon-6-7 battery cycles)
