Mamba MAX on savage
Vrooom666
Mamba MAX on savage - 03.26.2008, 05:28 PM
Any reason not to run stock mamba max ESC and 4600kv motor with 3s lipo on savage X?
i was told its bad idea as you can burn out the motor.
I am going do this as temporany postition until i got cash to buy new motor, cant you gear it down very low so it can pull itself ?
Jay
bdebde
That's All Folks!
bdebde's Avatar
03.26.2008, 05:38 PM
That rig is far too heavy for the mamba motors. Get a larger (Fiegao XL or Neu) motor and you can use the MM on 4s with external bec. You will likely burn up the MM motor in a short time.
Maxxman
03.26.2008, 06:00 PM
I run the MM in a FLM converted savage. The MM will be fine but the 4600 motor won't be up to much.
Vrooom666
03.26.2008, 06:03 PM
Which Fiegao XL 7XL or 8XL for my savage.
Im aiming for good run time. not interested in top speed.
Maxxman
03.26.2008, 06:08 PM
The 8xl will give you longer run times and tax the MM less but be slower. Although you could gear up a little to compensate fo the lower KV if you wanted.
83gt
03.26.2008, 06:23 PM
8xl is very fast on 4s. On 5s it's pretty stupid, lol. I'd think it would do well in the savage. I don't think i'd try a 7l, I'd think it'd run way too hot. A 9xl might even be a better choice, since the savage X is going to be quite heavy.
J.
*edit*
I see you want to run 3s. nix what I said up there. You could try a 7xl on 3s, but I think you're going to want more voltage before it's over and done with.
jnev
jnev's Avatar
03.26.2008, 07:34 PM
I'd go for 4s on the 9xl or 3 on the 8xl. 4s is ideal though. The Mamba Max motors will burn up in no time running them in a Savage.
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
03.26.2008, 07:38 PM
9xl, 4s, MM and a bec.
aqwut
Brushless Heavy Weight....
aqwut's Avatar
03.26.2008, 08:02 PM
I second that....
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
bdebde
That's All Folks!
bdebde's Avatar
03.27.2008, 12:20 AM
I third that.
Fast5sRevo88
03.27.2008, 11:31 AM
Jay
One thing i got to say; Ssssssssssllllllllllllllllllllooooooooooowwwwwwwww w!
