building a crt.5
rcfreek
building a crt.5 - 04.02.2008, 10:28 AM
please help me decide on a motor for my crt.5,i am just running on the road strickly speed!! i have the cc sidewinder esc already and i need a motor to work with it and also what battery will work best with it? please guys help me out as i have no clue and have been reading on here for months and i am ready to order?
also do i need the pinion mod? i have the motor mount and battery tray and the BCE extended chassis already,thanks guys
04.02.2008, 10:50 AM
Feigao 7L and 3s is fast for sure - ultimate is a quick neu 1509...
What pinion mod? if you get a motor with a 3.125mm shaft you'll need an adapter to use mike's pinions.
GO-RIDE.com
04.03.2008, 12:51 AM
I'd like to get a 1506 for my e-crt.5. Most guys feel the 1509 could push a 8 lb. 1/8 buggy as well as a high end .21 nitro, it just hasn't been tested yet. I bet a 1506 would be a rocket in a crt.5 and still have great run times.
E-8ight - Tekin RX8 2000kv/4S
rcfreek
04.03.2008, 10:20 AM
what about any motors on here?
http://www.hobbycity.com/hobbycity/s...4&ParentCat=59
04.02.2008, 10:56 AM
Run 3s and an 8L (around 34k rpm max). This will give you plenty of power and the ability to gear up and/or use larger tires without loading the motor too much. You could even go to a 9L if you wanted.
ren
ren's Avatar
04.02.2008, 11:56 AM
You could try the Medusa V2 36-50-3300 on 3s. It looks perfect for the Sidewinder. Be sure to report on your findings on this motor as well. Personally I am looking foward to trying mine on the Neu 1509/1Y (3s).
rcfreek
04.02.2008, 10:57 PM
what about any of the great planes ammo motors? can i run a outrunner motor? i had a duratrax vendetta 1/18 buggy i put a outrunner heli motor in it and it was a tourque monster and i could gear it up like crazy? just a thought?
04.03.2008, 11:29 AM
These might work... Look like cheaper feigao's
http://www.hobbycity.com/hobbycity/s...idProduct=6530
Feigao got fed up apparently with hobbycity not providing any service on their motors and stopped supplying them to HC.
rcfreek
04.04.2008, 10:19 AM
i orderd that motor and a 5000mh 3cell 11.1 lipo today from them? ill let you know how it goes? do i need the 5mm pinion from rc monster to work with that motor?
04.04.2008, 10:50 AM
Yes use BrianG's speed calc as it depends on tires but I think that would need about a 16T pinion
