general brushless question
DwightSchrute
I'm obsessed with The Office
DwightSchrute's Avatar
general brushless question - 05.11.2008, 10:31 AM
i found a good deal on some 12v mini cpu fans to use as a fan over my motor, but i'm running a 3s. Is that van too high a voltage? should i go to a lower voltage fan?
05.11.2008, 10:32 AM
No 3s will be fine - you will have a V slight overvolt to start with but generally will be running undervolted...
DwightSchrute
05.11.2008, 10:40 AM
what do you mean when you say :"you will have a V slight overvolt to start with but generally will be running undervolted"
do you think it'll take away from any performance?
SunnyHouTX
SunnyHouTX's Avatar
05.11.2008, 11:38 AM
I think what he meant was that there will be a very slight (~0.6V) overvoltage because 3S packs come off the charger at about 12.6V. After a couple of minutes of running, the pack voltage will go below 12V.
DwightSchrute
05.11.2008, 03:35 PM
thanks!! much appreciated.
brushlessboy16
brushlessboy16's Avatar
05.11.2008, 07:14 PM
Im running my 2 40mm 12v fans of two 9v batts in series, they hold up fine
