i found this from a different site but had to get one and do a write up on it
i got this al. case at Menards,in the hardware section, im sure other hardware stores will have them as well, it cost like $20...and it fit alot of stuff, it is wired up underneath the foam so i can plug my charger in directly
best of all its orginized
dont know yet, but when i charge my batterys at room temp. the fan on the power supply only kicks on the last 15min. of a one hour charge, ill post it up if i run into problems
Those generic cases are awesome! I got one from the LHS I work at for like $10 that's about half that size - it's PERFECT for my Nomadio React radio. Looks like yours will be very handy .
Do you by chance know how to set up the 989 to charge two NiCd's? My serial adaptor is set up right, it just seems that I cant get the settings right to make it charge them together.
