Holes in Your Tires?
Sower
Sower's Avatar
Holes in Your Tires? - 05.30.2008, 09:55 AM
What do you guys use to drill holes in your tires to let dirt and water get out? I've never done it before and just got some new tires. Do you just bust out the drill and go for it or is there some technique someone can point me to? Thanks!
MBX6T Tekin RX8 5s Neuenergy
www.robsower.com
skellyo
skellyo's Avatar
05.30.2008, 09:58 AM
You run the risk of tearing the rubber or getting non-uniform holes if you use a drill.
I use a leather punch tool, like this:
http://www.amazon.com/eToolscity-TAI.../dp/B0002T87FE
I picked mine up from Home Depot and it's almost identical to the one in the link. Works very well and punches nice round holes.
Sower
Sower's Avatar
05.30.2008, 10:00 AM
Well, that would work if I didn't buy pre-mounts.
www.robsower.com
skellyo
skellyo's Avatar
05.30.2008, 10:06 AM
Unfortunately, I think your only feasible option is to drill the wheel itself.
I tried this once on a set of stampede talons and it was a disaster.
I just took a 3mm drill too them - sadly when running on brushless power I managed to get a whole foam out through one 3mm hole.
On the other tire it ripped to shreds! I obviously did it very wrong and am interested to see how to do it right.
Proceed with care though!
05.30.2008, 10:10 AM
I still say tires should be sealed and air filled just like real tires. Sure, makes them a bit bouncier, but nothing that can't be dialed out via suspension tweaks I would think.
lutach
lutach's Avatar
05.30.2008, 10:55 AM
A company in China has made one and it uses an inner tube and there's a little vlave just like a real tire.
05.30.2008, 11:08 AM
How does it hold up?
lutach
lutach's Avatar
05.30.2008, 11:56 AM
Don't know. I never got one and it looks kind of heavy. I'll try to find some pictures and I'll post them here.
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
05.30.2008, 11:59 AM
I've had good luck using a drill bit in a dremel tool. It spins fast enought to melt through it rather than tear it.
05.30.2008, 12:01 PM
I imagine it would be heavier. Hmmm. Maybe get rid of the tube for a belted radial? And use a different solution instead of a valve stem?
lutach
lutach's Avatar
05.30.2008, 12:15 PM
Found it, but I can't find the other ones. I will have to find the pictures that I printed and scan them.
05.30.2008, 12:21 PM
Wow, 1.1lb per tire??!! They are bigger than normal at 6.5" D X 4" W, but still. The rims look like Al, maybe a high grade plastic would be better. Wonder how heavy a typical on-orad, buggy, or MT/truggy tire would be...
bdebde
That's All Folks!
bdebde's Avatar
05.30.2008, 01:06 PM
I have some 40 series tires that weigh about 1 lb.
rcsammy
buggy beater
rcsammy's Avatar
05.30.2008, 02:02 PM
fastrax make this tool
Make quick and easy air holes in your tyres with with this new purpose designed tool from Fastrax. Its special inwardly rotating barrel allows pressure to be applied while the cutting tip cuts through the tyre wall producing perfect holes every time
  Send a message via MSN to rcsammy
