What Neu Motor for CRT?
DiFabio42
What Neu Motor for CRT? - 06.26.2008, 03:32 PM
Hi Guys.
I might convert my Jammin' CRT to Brushless and screw Nitro for good!
1. What Neu motor is the best combo of Speed/Torque?
2. What Gearing is the best for staying cool and a good Speed/Torque Combo?
Thanks Guys.
06.26.2008, 04:32 PM
I'm a fan of the 1515 2.5D/F 5/6s on appropriate gearing - use brian's calc
DiFabio42
06.26.2008, 04:53 PM
Ok, Thanks.
What the Differential Ratio?
06.26.2008, 05:01 PM
Divide the diff ring-gear tooth count by the diff pinion gear tooth count.
And once you find out the tooth counts, let me know and I'll add it to the calc (note: I need the tooth counts, not the resulting ratio).
DiFabio42
06.26.2008, 05:06 PM
I can't find the Ring Gear and Diff Pinion anywhere.
06.26.2008, 05:19 PM
Did you try looking in the manual? Ofna is usually pretty good about putting tooth counts either in the exploded views or in the parts list.
skellyo
skellyo's Avatar
06.26.2008, 05:17 PM
I run a Neu 1515/1Y/F on 4S geared at 13:62.
DiFabio42
06.26.2008, 05:56 PM
How fast is the Truck going?
cemetery gates
06.26.2008, 09:14 PM
I also run a Neu 1515 1/y/f on 4s geared 14:62, I would guess it hits 35-37mph.(this is in a crt)
Bye
DiFabio42
06.26.2008, 10:13 PM
Bye
1. How about on 6s? How much faster will it go?
2. Would the 1515/2.5d be faster?
skellyo
skellyo's Avatar
06.26.2008, 10:45 PM
36mph according to my GPS. With the temps I get though, it could easily be geared for 40+mph and be within an acceptable temp range.
DiFabio42
06.27.2008, 09:00 AM
Not bad.
Is a 2.5D on 6s faster?
43/13 Iirc
Yip - checked in manual http://ofna.com/pdf/34963-x1crt-pro.pdf Page 1 & 2
Steve Krug
Steve Krug's Avatar
06.26.2008, 10:33 PM
Not Fabio..........lol
You've got to run lipos buddy.
Neu 1515/1Y/F on 4S is the fastest, cheapest route probably...
DiFabio42
06.26.2008, 10:39 PM
I am running Lipo.
What do you guys say?
1515/1Y on 4s?
or
1515/2.5D on 6s?
