Quick help please - stripped wheel nut.
VintageMA
VintageMA's Avatar
Quick help please - stripped wheel nut. - 06.28.2008, 10:00 AM
After having the wheel nut come loose and almost lose it I blue thread locked all the wheel nuts. When I went to change the wheels last night I got all but 1 nut off. It is on so tight that I stripped a socket wrench and the head of the nut - so there is nothing to grab onto right now.
I've tried heating it up with a blow torch a bit to loosen the thread lock, but I still can't loosen the nut.
FYI - this is the 14-17mm adapters that come with the HPI pre-mounted Phatlines. The metal on the nuts is very soft.
“Everyone has a right to be stupid; some people just abuse the privilege.”
david lamontagn
06.28.2008, 10:34 AM
Take your iron heat and put it on the nut, not on the axle, you want to heat the nut only, to make the nut take some expension.
When the nut will be heat enough, take a pair of chanellock pliers, like this http://www.northerntool.com/webapp/w...8919_200308919, and try to loosen up your nut.
This is the only thing you can do
lutach
lutach's Avatar
06.28.2008, 10:47 AM
+1. Everything David said will do the job.
david lamontagn
06.28.2008, 10:55 AM
And for the thread lock, did you use red or blue?????
Never RED, always go BLUE
VintageMA
VintageMA's Avatar
06.28.2008, 11:33 AM
No worries - blue on the threadlock, maybe just too much of it - and the HPI nuts have that wheel lock ribbing on the inside edge.
06.28.2008, 11:57 AM
I cut one in half with a dremel once, worked, but only use it as a last resort.
azjc
06.28.2008, 12:06 PM
sounds like soft aluminum... the pivot ball cap that RPM makes for the Revo and Maxx is really soft I wouldnt mind a steel one
VintageMA
VintageMA's Avatar
06.28.2008, 05:07 PM
I tried every wrench I had in vain. Even went out and got a vice grip wrench, just not enough to grab with the plastic of the wheel surrounding the nut.
Ended up dremelling through the wheel to cut it out and then get the nut out from the side.
Got the Ofna 17mm adapters from the LHS this afternoon and they are 2000% better. So nice to have that 17mm wheel nut back - no stripping one of those.
Thx guys.
azjc
06.28.2008, 08:58 PM
Thx guys.
which brand of 17mm adapter were you using? I am using the Maximizer ones
06.28.2008, 09:01 PM
Thanks for using my idea!
lutach
lutach's Avatar
06.28.2008, 09:09 PM
One tool that has always been my best friend is the good old "DREMEL".
