Feigao/Nemesis/Wanderer query -
08.20.2008, 10:50 AM
are these motors all exactly the same to the point if i wanted to run two i could run a nemesis 8L next to a Feigao 8L and one wouldnt be carrying the other?
its a hyper 7 to enter in the worlds fastest RC max speed with that motor assuming its does the rated 2000 and assuming no losses 24/44 gearing is 100mph
problem being im using a MM ESC and it wont supply the amps it would need
hence doubling up as i dont fancy my chances of getting a MMM in time
It would be a lot easier to use your MM in your ZX-5 instead of the big Hyper 7. Youre gonna pull a lot of amps in your Hyper 7 and you can get more speed out of the zx-5 with a less powerful setup. Are you on Fast-RC forums?
