v2 on 6cell lipo who still alive?? -
09.25.2008, 06:45 PM
i know that a lot of thread was made on the mmmv2 but i just want to find the guy's who run the v2 on 6 lipo cell or the equivalent on life-po (with the internal bec) and still running stong!!!!!
for me i never pass over 25min on 6s
Yip Yip Yip...
09.25.2008, 07:42 PM
Mine is fine but I have the red wire pulled and I am using an external bec. I killed two before this though with out the external bec.
09.26.2008, 10:20 AM
ive had two v2's go bad on 2 x 3s 5000hv maxamps,using internal bec, getting another this week ill let ya know how it goes,....
I don't understand, but I don't think I like it.
09.26.2008, 10:32 AM
I have a v2 that runs fine on 2 Maxamps 3s 5000mah in series using the internal bec and I also have a v1 but I'm using an external bec on it.
09.26.2008, 04:28 PM
Originally Posted by JerryF504
I have a v2 that runs fine on 2 Maxamps 3s 5000mah in series using the internal bec.
your the only one  i try my third one unit yesterday with the internal bec...no issue but i was to scared to see my e-revo stop in the middle of my run....  however i installed a ext. bec just to be sure....work great so far....close to 3 hour on it!!!!!
09.26.2008, 04:59 PM
I've got one running two 3S TP 2500mAH lipos in my Rustler. Don't have much runtime on it due to lack of time to test. Will know more tomorrow.
09.26.2008, 05:19 PM
That should be interesting a 6s MMM rustler. Just a v1 on 6s for me.
09.26.2008, 05:32 PM
Note: MMM failures are not related to input voltage; they can die just as easily on 4s as they can 6s. Until the exact cause of failures is determined, assuming the voltage being used is too high is just plain daft....
09.26.2008, 05:42 PM
are sure????i dont really unterstand why some failed and not...each esc had the same built....and same part....
RC-Monster RC8T
09.27.2008, 07:02 AM
All 1:1 cars have the same build too, why do some go 300,000miles and some go 50,000? There are bound to be failures on everything. example anything that is cast could get an air bubble in it and wouldn't be detected on the outside, but when it fails you'd know, and the one right before and right after could be perfectly fine. Anything on this planet can fail at anytime for any reason - that's life and the sooner you come to realize and except that the sooner you will be able to enjoy life. Some MMM die at start up, some die after a few seconds, some after a few minutes, and some after a few hours. There's really no way of knowing, just know that if it does CC will take care of it!
09.27.2008, 10:43 AM
nothing more to say  your right
09.27.2008, 04:14 AM
I've been running mine (V2) in stock form on 6s for 3 weeks now with no issues.
09.27.2008, 05:07 AM
v1 6s with a neu 3d, still running strong.
Kyosho SC, tekin rs, D3 17.5
Hyper 9e, mmp,tekin 1900kv
Something, anything, nothing
09.27.2008, 10:47 AM
Had mine on 6c Flightpower with a 2.5d since I bought it. All has been well.
09.27.2008, 11:32 AM
got two here run on 6s lipo and 7s a123 running box stock, probably an hour or so or more on each and no sign of trouble yet.
