09.26.2008, 05:32 PM
Note: MMM failures are not related to input voltage; they can die just as easily on 4s as they can 6s. Until the exact cause of failures is determined, assuming the voltage being used is too high is just plain daft....
e-mike
e-mike's Avatar
09.26.2008, 05:42 PM
are sure????i dont really unterstand why some failed and not...each esc had the same built....and same part....
D8t on juice!!
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
09.27.2008, 07:02 AM
All 1:1 cars have the same build too, why do some go 300,000miles and some go 50,000? There are bound to be failures on everything. example anything that is cast could get an air bubble in it and wouldn't be detected on the outside, but when it fails you'd know, and the one right before and right after could be perfectly fine. Anything on this planet can fail at anytime for any reason - that's life and the sooner you come to realize and except that the sooner you will be able to enjoy life. Some MMM die at start up, some die after a few seconds, some after a few minutes, and some after a few hours. There's really no way of knowing, just know that if it does CC will take care of it!
e-mike
e-mike's Avatar
09.27.2008, 10:43 AM
nothing more to sayyour right
D8t on juice!!
