Who Can rebuild Lipos? -
10.22.2008, 06:51 AM
Im looking for someone to remove dead cell from my 5s zippy pack.. my momster ate it...
10.22.2008, 08:21 AM
da pimp...
10.22.2008, 10:10 AM
Woot!
10.22.2008, 06:19 PM
ok, i would need one cell removed...
Its an odd problem. all the cells are reading 3.87v except for one which reads 0.0v and i get no votage through the deans plug. like there is a physical break somewhere as there is no puffing or anything visible..
also i have one cell with a loose cover, not sure if its the cell casing itself or just a plastic film. the cell hold voltage well and is balanced with all other..
Thank you for the help
10.22.2008, 06:23 PM
Sounds like a physical break all cells may be fine
10.22.2008, 07:30 PM
10.22.2008, 07:44 PM
That pack looks like the cells are soldered together. Showul be easy enough to seperate the cells and check them individually. I would remove the bad cell asap. Leaving a bad cell in the pack can kill the others...
Dsm needed
10.22.2008, 07:36 PM
Bathroom? water + lipo = BAD
Soldermaster Extraordinaire
10.22.2008, 07:50 PM
Awe it's the middle cell too! That's a pain. Sorry for your loss(es).
since yesterday voltage in the cells has not moved.. im afraid to solder lipos  dont have a very steady hand
10.22.2008, 07:54 PM
Oh that would be too easy to comment on....
Just use some tape to cover up the areas you are not try to heat up. Or send it to me...
10.22.2008, 07:57 PM
yeah with you its either make things so bland that you wont comment, or make them so outrageous that it is blatantly obvious what can be said....
seemed to work nicely eh?
ill try and see what i can do..
seems like there is a plastic ladder-like thing in there.. hope it wont be a problem
10.22.2008, 07:55 PM
Parkingson + solders lipo = BOUMMMMMMMMMMM
10.22.2008, 08:59 PM
AHA! I found it, the number four cell has its tab broken off..
10.22.2008, 09:07 PM
You will most likely not have much luck fixing that, they usually break off too close to the foil to get to. Maybe a pic would help...
