Just downloaded my data logger after the first run with the new MMMv3 and I think the motor may be bad. With a very short run and only really gassing it for about 3 seconds, my motor temp hit 200f and had an amp draw of 174!! I was hardly getting on it at all and did a whoping 15-20mph. I did not get a good rpm reading due to settings being wrong. My sig has the specs...gears are54/16.
Do I have a bad motor??????
FLM Extended Savage -Nue 1521 2d MMMv3 6cell E-Maxx -Flm Parts stock motors (the wife's) Slash -MM medusa 3300k 3cell 68 mph!
[B]Custom FLM Axial Crawler Losi Rammunition 1/184600k
The Feigaos are 2 pole motors. The screws being refered to are the ones that hold your motor on the truck, they go through the front endbell and if they touch the windings thats a big problem. Check your slipper though! may be loose causing the motor to rev way to fast heating it up and causing very low top speeds
