Looking for a oddball inrunner
Looking for a oddball inrunner - 01.09.2009, 01:32 AM
Ok, I have a project that needs a weird motor. Dimensions need to be like a std 540 brushed motor, so 36mm diamter, 50mm max length (preferably shorter) with a 25mm mount pattern with m3 thread, and a 1/8 shaft.
Now for the special part. I would like a 6 pole motor, and a kv somewhere around 1500. Now anything from 1000kv to 2000kv will be useable...
Something capable of about 300watts would be desirable.
So get to if fellas! I know some of you can find just about anything...
jayjay283
jayjay283's Avatar
01.09.2009, 01:35 AM
the pimps drinking again, we best find him his motor or we are going to get dildo wacked
01.09.2009, 02:26 AM
Oh yeah, double-ended too!
01.09.2009, 01:39 AM
Something like this would be cool, but needs lower kv...
http://www.hobbycity.com/hobbycity/s...trunner_2900kv
jayjay283
jayjay283's Avatar
01.09.2009, 01:40 AM
I have a 5mm brushled
motor that could bull a truck out of an alligator pond, Snowman 78 ? sorry if off sent it to me i wen brushless, 720 id say no identity on it but big fooker
jayjay283
jayjay283's Avatar
01.09.2009, 01:41 AM
art attack snowmobile, not sure if its it but its 2x any emaxx motor ( brushed bitch)... its huge you need it $5 as usual check this dog out
01.09.2009, 02:27 AM
I will pm you in the am... Later than now... I am sure that I can find a use for it!
01.09.2009, 02:43 AM
rated 35a 11.1v (388w) shorter than a 540, but with a 5mm shaft(i know a guy that can have it turned down for you)
http://www.puffinmodels.com/product.php?prod=818
woops, its 12 poles. popped up on a 6 pole google. I'll look again.
01.09.2009, 10:23 AM
Here you go, this meets all criteria except for the 3.2mm shaft part, this one has a 5mm.
http://highendrc.com/index_eproduct_...products_id=50
01.09.2009, 11:02 AM
12 poles is ok, looking for a torquey motor. I may go down to the 22/10/8 as it is around 1500kv and shorter. The can length is my main spec I have to meet as space is at a premium...
Bit too long, but thanks!
01.09.2009, 11:13 AM
I think based on dimensions you are going to put a motor in place of diff cup?
01.09.2009, 03:20 PM
No but that does sound cool...
It is going in my 6x6 tlt axle based crawler. Tight squeeze with the links and driveshafts.
