possible differential problem... -
04.03.2009, 01:36 AM
hey guys
i have an erbe and so far have only ran 12cell nimhs which belong to my friend. the gearing is 18/54. the rear differential has a "sticky" spot. when i spin the spur it gets slighty hard to spin for like an 8th of a rotation then it is free. i hear the noises coming from the rear diff. its not the center driveshafts. maybe a bent pinion tooth? it always happens one rotation of the half shafts any help appreciated.
thanx
haha. ill stick with stockers til they blow and buy more stockers. could a replace anything. like a pinion or ring gear? or should i buy i new diff?
Generally good to replace the ring and pinion at the same time. Pick up some shims too, and spend some time getting the mesh just right. That time will pay off with much longer component life!!!
thanx for the tip. ill open it up tomorrow for closer inspection. can i get a link for some diff shims?
