KB45 front endbell stripped, now what? -
04.03.2009, 08:02 PM
The screwed on front endbell of my kb45 is loose. When I ran it it just spun on the mount. (not the endbell, that was tight to the motor mount, the whole rest of the can and wires spun) The only thing that stopped it was those darn stiff tinned motor wires, which now looked like braided line.
So now what? The threads are toast, so I can't just loctite it and retighten it.
04.03.2009, 08:06 PM
Jb weld and an overnight dry... You should have enough threads left to get it to start and hold while it dries.
04.03.2009, 08:09 PM
Drill out and tap for M4 - Then use one of mikes end bell covers :) to get you 4 spangly new m3 holes
04.03.2009, 08:20 PM
Will that hold the weight? That's a lot of motor hanging out there.
Not the screws in the endbell, the endbell in the can is stripped. So the threads of the endbell itself and the corresponding threads in the motor can are stripped. (Its a screwed on endbell)
a kb45 sized rcm heatsink/clamp would work
04.03.2009, 09:25 PM
JB Weld is quite gangsta, if you get it clean, and use the original formula jb, not the quik, it will work well. I have fixed all kinds of stuff with jb, especially for high heat it is about the best stuff out there.
04.03.2009, 09:29 PM
Got some in me toolbox(fishing tackle box) I will try it. If it comes loose again that bee-yatch is getting tig welded
04.03.2009, 08:26 PM
Time for an upgrade?
04.03.2009, 08:29 PM
but I've only used it once! only on 3s! frickin frick
04.03.2009, 08:53 PM
Did the threads on the can or the endbell strip? Both?
04.03.2009, 11:08 PM
2 part epoxy also works well :)
04.03.2009, 11:39 PM
Make sure it is high heat... JB is one of the few easy to find high temp epoxies...
04.04.2009, 02:08 AM
I had a kd 9xl That the can was stipped on, you could pretty easily keep turning the endbell, jb weld did the trick on it
04.04.2009, 12:12 PM
That makes me feel better. Is JB Weld the new duct tape?
04.04.2009, 12:24 PM
JB is the permanent version of duct tape...
There is no help for me... I'm addicted to R/C
04.04.2009, 01:43 PM
I can a test to that. At my old job we fixed a cracked block on a M5 with it, just to get the car mobile so the customer could use his car. When the new engine came in we were surprised that the JB was still holding with no leaks.
