Shortening or lengthening wire on Neu/Castle 2200kV motor...is it ok?
Chadworkz
UE Supermaxx Addict!
Chadworkz's Avatar
Question Shortening or lengthening wire on Neu/Castle 2200kV motor...is it ok? - 04.24.2009, 02:42 AM
My ESC was mounted to the top of my transmission in my Revo (nitro conversion), and when the truck flipped over and slid down the road, it ground through all three motor wires...is it OK to remove the bad section of wire and solder the two ends of each wire back together?
Also, I would like to move the ESC to a custom carbon-fiber tray I built, but the motor wires are about an inch too short...is it OK to lengthen the wires by about an inch or so?
Thanks in advance for any help you can provide.
-Chad
PM ME IF YOU HAVE THE BELOW:
04.24.2009, 02:47 AM
You can shorten the wires, and you can lengthen them too. Try to keep them as short as possible (good rule of thumb about any rc wires, save for the antenna), and you may want to braid them to help with support and rf interference. Also try to support the wires with a stand or ziptie so that they cannot move around, as that can cause solder joints to break.
Chadworkz
Chadworkz's Avatar
04.24.2009, 02:55 AM
Man I am glad you are up late like me, heh!
So, you think adding an inch to inch and a half will be fine?
-Chad
04.24.2009, 03:06 AM
Sure, if it give you problems at least you know...
Chadworkz
Chadworkz's Avatar
04.24.2009, 07:05 AM
I just went ahead and soldered them back together without adding any length or removing any length, so we will see how it does tomorrow. Thanks for your help, man, I really appreciate it.
-Chad
04.24.2009, 12:18 PM
No prob, good luck with it. And always run your body on...
Chadworkz
Chadworkz's Avatar
04.24.2009, 07:57 PM
Yea, no kidding...I made my old T-Maxx 2.5 Pro-Line GMC Sierra body fit until I get around to painting my new Revo 3.3 PROTOform HardDrive body!
-Chad
loa
06.16.2010, 12:41 PM
Hello,
I just received my CC-Neu 2200 from Mike (very fast shipping!) and find the 3 wires on the motor *very* long. I know some wires cannot easily be cut and re-soldered.
A year later, is that advice still good?
Thanks
Loa
06.16.2010, 12:49 PM
Castle/Nue motors are not the same as "real" Nue motors. Castle's motors are set up where the coil wires are attached to "noodle" wires inside the motor. So you can cut the wires down to whatever you need. On real Nue motors, the motor wires are just extensions of the coil wires, so you can't easily shorten them without special consideration.
loa
06.16.2010, 12:51 PM
Thanks for the confirmation.
Loa
06.16.2010, 03:06 PM
castle 1717 Air motors can NOT be shortened...
