Originally Posted by traxxasbasher13
Let us know how it works.
BTW: Did you read the "important note"?
Important Note: this ESC is Opto, without BEC supplying power to your Receiver, you need extra power source for your receiver. You can use a UBEC, a voltage regulator, or extra batteries as the power source for your receiver. If you hear the music tone repeat again and again for more than 3 times, you may need to check your power source to the receiver.
So, you will need a seperate BEC, and do not remove the red wire in the throttle cable.
