Originally Posted by superek4
got a question. I raced with a 1600kv medusa 12pinion for 20min temp was 140F, with 50 slip diff.
Today I tried my 2000kv with 11pinion within 11mins the temperature was 176f I had to stop before the motor burn.
What is the advise? Run 1600 higher pinion or 2000 lower pinion?
Hope to get 35mph n above without overheating.
Try lowering the pinion count on your 2000kv motor. If you calculate using power, your 2000kv motor is giving out more power than the 1600kv motor which explains why it heats up more. Even with a 11T the 2000kv motor on 6s still output more power than a 1600kv with 12T.
If all else fails, try lightening the weight of your truck.
