I don't think it would be able too. From what I read (in the reviews section at HC) they are setup/programmed to work with certain system. Don't know the jargen and hobbycity is down. The question was asked there also and the explaination was a little more technical but those also will only work with the brand they are made for also. It would be nice to get a hold of less expensive receivers for transmitters.
It should work with the m8/m11 2.4Ghz modules and anything else that uses the FHSS type modulation...however Airtronics uses the FHSS-2 and FHSS-3 so I'm not completely sure.
the little losi 2.4ghz rx works fine with all the spectrum tx and tx modules.... ive got two of them and 3 spectrum rx's all work fine with any of my spectrum radios.
