I have a crazy brother that wants to make th most over-powered slash possible. He wants to run a MMM 2650kv system on 4s. Has it been done? From preliminary measurements I dont think the motor (41.78mm diameter) will fit in the gear box. So he would need a FLM tranny case, but then there is still the question of if the size of the motor will allow it to have good gear mesh with different gearing options. Has anyone tried it, or have any input?
you would be better off getting the 2200kv motor if you want the most power possible. the can on the 2200kv motor is longer and you would be able to gear it to the moon.
