Will a zippy fit in a Slash?
jacobsjo87
Will a zippy fit in a Slash? - 08.25.2009, 11:01 PM
Does anyone know if the zippy packs will fit in a Slash battery tray? I want to get this pack but I don't know if it will fit or not.
http://www.hobbycity.com/hobbycity/s...0mAh_3S1P_30C_
fastbaja5b
fastbaja5b's Avatar
08.25.2009, 11:15 PM
They do fit but you need to dremel a bit for clearance for the wires to exit the pack. They fit well in the Slash, but the Stampede / Rustler / Bandit need a fair bit of dremel work all round.
Say Less, Do More.
brushlessboy16
brushlessboy16's Avatar
08.25.2009, 11:17 PM
they are one millimeter wider then the 4000packs, the 3s 4k pack is a snug fit in my slash.. it just might be possible... might need some light dremel sanding though.
You will need a notch for the wires to come out through.
maxair45
maxair45's Avatar
08.26.2009, 12:21 PM
Dang that doesn't look safe. Wheres the shrink on the motor wires?
Don't run it until you dremel the notch in the side. It'll pinch the wires and most likely destroy the battery(check the biggest blunders thread for the full story).
brushlessboy16
08.26.2009, 04:54 PM
clear heatshrink from radio shack. works just the same
Unsullied_Spy
Unsullied_Spy's Avatar
08.25.2009, 11:36 PM
The 5000 mAH 25-35C packs fit in my Rustler very tightly, I'd say that with a little Dremel work that should fit yours just fine.
jacobsjo87
08.26.2009, 12:20 AM
Maybe I will just go for the 4000 to be on the safe side.
rawfuls
roofles.
rawfuls's Avatar
08.26.2009, 12:34 AM
Man.. I really need a dremel...
I have a few packs that need notches, and I has no dremel.
shenanigans.
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
08.26.2009, 12:51 PM
You can pick up a dremel knock off super cheap at Harbor Freight and Tool.
http://search.harborfreight.com/cpis...rd=rotary+tool
I have that 23.99 red one, I keep out in the shed. It's my
workhorse/sacrificial dremel and have had it 4-5 yrs and it has ben used a LOT, still works great and lots a power.
e-rev project
08.27.2009, 09:39 PM
shenanigans.
if you can go to costco they have a decent dremel type (not dremel brand) kit for about 20 bucks w many bits and cut discs, ive used the crap out of mine and it is still kicking. i fried my dad's dremel brand cutter years ago lol
08.26.2009, 01:05 PM
I didn't want to chance compromising the structural integrity of the chassis by dremeling the sides, so I just mounted the battery on edge and added a little bit of rubber-foam weatherstripping padding on the sides:
Foxracin
08.26.2009, 01:10 PM
Also for a cheap dremel check Autozone if there is one around you. I got the one I used for $16. Its super cheap and works great. I have had it for about a year now and use it a couple times a week and it has held up great. Has about 7 or 8 speed adjustments on it also. Cant beat it for the price.
Edit: Here is the one I was talking aout. It lists for $19.99. Come with a case and assorment of bits.
http://www.autozone.com/autozone/cat...ame=Great+Neck
eovnu87435ds
A 16yr old with a combover
eovnu87435ds's Avatar
08.27.2009, 08:56 PM
Brian, just curious, whats that servo for?
Hyper 7
BARBIE JEEP!!
CRT.5
TC4
RC18B
rawfuls
roofles.
rawfuls's Avatar
08.27.2009, 10:07 PM
Meh
I should get one sooner or later...
