Futaba R113IP receiver and MMM
winkje
Futaba R113IP receiver and MMM - 09.22.2009, 03:48 PM
Hi,
I had to find out the hard way that the well known and highly appricated Futaba R113IP receiver is not working with a MMM combo.... Or better, the other way around. I have informed CC about this several months ago and have received a couple of emails from them in which they confirmed the issue and also informed me that they would take action.....
Words have remained words up till now, no solution from CC.... anyone with a suitable solution?
Regards, winkje
brushlessboy16
brushlessboy16's Avatar
09.22.2009, 04:03 PM
What do you mean that it "isnt working" as in glitching? as in not working at all?
winkje
09.22.2009, 04:10 PM
Hi,
Sorry... no glitches but simply impossible to calibrate the ESC.
I copied this text from the message I got from CC:
I wrote:
Hi,
After a long and frustrating evening I couldn't get my new Mamba Monster Max calibrated on my Futaba T3VCS and 40Mhz 113ip receiver... I extensively searched the web and found a posting about an issue with the Mamba Monster Max and the 113ip receiver. Couldn't believe it but to be save a changed to a 146ip receiver. It calibrated within a minute and works fine....
CC reply:
We have one of these coming in and will be doing testing with it. A gentleman had 12 of them, 10 did not work, 2 did. We're wondering if Futaba changed something without telling anyone that could be keeping it from working.
JThiessen
JThiessen's Avatar
10.28.2009, 11:14 AM
Any update on this?
I am having issues calibrating my brother in laws Futaba 3PM to the MMM. I am completely unfamiliar with how to adjust the settings on the Futaba - and I can't ask him 'cause I'm putting the MMM/2200 in his truck as a "gift" to him. I'd almost prefer to simply reset the Futaba back to factory settings and start from there. But I remembered reading about this issue and was curious if anything came out of it.??.....???
Gee
A Horse's Ass
Gee's Avatar
10.29.2009, 01:32 AM
I had some difficulty with my Futaba 4PK today. Been using it mainly in the nitro rcs this summer but I converted my XL to brushless yesterday so first time trying to calibrate it to a Castle Creatons product. I had to increase the dead band in the Castle Link softare for it to calibrate. I also increased the arming time a little. One of them did the trick and it calibrated fine once I reversed the throttle on the transmitter that is. I use to have that problem when I had my 3PM FSPro w/ the MM. Can't remeber how many models the 3PM can hold but on the 4PK I just added a new model for the XL Brushless. That way I was sure all the setting were reset.
winkje
12.22.2009, 02:56 PM
Hi,
It's been a long time.... ;-)
Thanks Gee for pointing me into a direction I haven't tried anymore. Must admit I'm really disappointed with the service CC has delivered here; my last emails regarding the status have never been answered even though CC promised to look into it.....
If the solution Gee described does not work I'm afraid a will leave CC and advice some of my friends looking into Brushless setups to look at alternatives as well.... too bad as I honestly liked the previous CC products I owned.
Keep you posted!
Regards, vincent
12.22.2009, 03:08 PM
Before you call it quits on CC, I would give them a call. It is the busy season, and even then, they have been really busy. Your email probably got lost in the shuffle. It's a relatively small shop for the amount of products they produce.
Pdelcast
Pdelcast's Avatar
12.22.2009, 04:26 PM
Also, have you tried contacting Futaba? If one single receiver doesn't work with a particular ESC - - then it would seem to me that the fault lies with the receiver, not the ESC.
Patrick del Castillo
President, Principle Engineer
winkje
12.23.2009, 05:09 PM
Hi,
Must admit being surprised by such a reaction from a President of CC.... Instead of "sorry, seems we overlooked something" you give me the "let's play the ball into the other corner"..... Communication is key and even after sending reminder emails I simply get no reaction from your company. If you simply asked your support guy about our communication you might have understand that I tried multiple different R113IP receivers already; all failing with the MMM and lovely working with alternative brushless setups. What a missed opportunity...
@suicideneil; yes, with the R146iP the issue is solved. The only downside of this is that the R146iP is a low range 6 channel parkflyer receiver where the R113IP the best long range range 3 channel receiver is Futaba created for PCM. Besides that, I have 4 R113IP receivers and just 1 R146iP which is in use for a different model already and all 4 failed the test....
@andywpj; Thanks for your solution. I still haven't tried the previos mentioned solution but you seem to have offered the safetynet. Thanks for that!
@BrianG; thanks for your reply. Yes, it could be that CC is too busy for answering support calls due to the season but I started communication already 5 months ago.... However, your reaction is valid and I honestly hope this is the reason instead of "we don't know how to solve it, so let's not talk about".....
Regards, vincent
Pdelcast
Pdelcast's Avatar
12.30.2009, 08:33 PM
Originally Posted by winkje View Post
Hi,
Regards, vincent
OK, so I guess it's our problem that Futaba decides to ignore the accepted standard and release a receiver that doesn't conform?
There are accepted standards in the RC industry. Manufacturers are expected to conform to the standards. If one manufacturer decides to ignore the standards, why is it the responsibility for other manufacturers to adjust?
The correct course of action is to bug FUTABA, who decided to ignore the accepted standards in RC, TO FIX THEIR incorrectly designed receiver.
The MMM accepts a 2.0 - 5.5V logic level pulse train at 20-100 hz. The valid pulse width range is from .8ms to 2.4ms -- which is WAY more generous than the accepted standard.
The fact that some other manufacturer's devices work with the poorly designed Futaba receiver has more to do with luck than anything else. A large percentage of MMM controllers work fine with the R113P -- but some do not. This is because the R113P is right on the edge -- about a 1.8V output logic level. -- NO OTHER MANUFACTURER has EVER release a receiver that outputs less than 3.3V logic level. Futaba themselves have never released another receiver that outputs less than a 3.3V logic level.
So, my stand is: Futaba decided to ignore the accepted standard on one particular product. The proper course of action is to tell FUTABA that their product is defective, and ask for a fix. NOT to go to EVERY OTHER manufacturer, and ask them to change their design to fit a non-standard RX from Futaba.
Thanx!
Patrick
andywpj
12.22.2009, 09:45 PM
Hi,
Regards, winkje
Hi,
i am sure R113ip can't work MM/MMM esc.
because R113ip is a PCM receiver, it build in pcm decoder IC , decoder IC work voltageic 3V ,output single voltage level between 2.6V~2.8V,
ESC can't identification right level. so sometime maybe work, maybe no.
you can solution issue.
just put a fail-safe in R113ip and MMM.
Pdelcast
Pdelcast's Avatar
12.23.2009, 12:55 PM
Originally Posted by andywpj View Post
Hi,
Well, the MMM only needs a logic level of about 2.0V to operate. So that's not the problem.
jokerjustin
RC-Monster Cheap Ass
jokerjustin's Avatar
12.23.2009, 01:52 PM
12.23.2009, 01:57 PM
Originally Posted by jokerjustin View Post
Thankyou for that helpful post, really goes a long way to resolve the OP's issue.
EDIT:
Err, so its working fine now with the new/different rx? Seems like you dont even have an issue anymore?
Unfortunately digital radios seem to be very tricky sometimes to get working correctly with various escs- its just par for the course with the r/c hobby (ergo- try a different radio to diagnose the issue; if a different radio works fine, then you should take the issue up with radio equipment manufacturer and not the esc manufacturer, since the esc works fine )...
brushlessboy16
12.23.2009, 05:50 PM
Just tried this with a buddies 3pk! does the same thing- Just not compatable..
But for some reason the steering servo works fine.
esc goes crazy and LED's are all over the place. was up all night trying to figure it out
