Originally Posted by winkje
Hi,
I had to find out the hard way that the well known and highly appricated Futaba R113IP receiver is not working with a MMM combo.... Or better, the other way around. I have informed CC about this several months ago and have received a couple of emails from them in which they confirmed the issue and also informed me that they would take action.....
Words have remained words up till now, no solution from CC.... anyone with a suitable solution?
Regards, winkje
Hi,
i am sure R113ip can't work MM/MMM esc.
because R113ip is a PCM receiver, it build in pcm decoder IC , decoder IC work voltageic 3V ,output single voltage level between 2.6V~2.8V,
ESC can't identification right level. so sometime maybe work, maybe no.
you can solution issue.
just put a fail-safe in R113ip and MMM.
