mbx5t-6t compatibility?
kneedeeppow
is lovin life brushless
kneedeeppow's Avatar
mbx5t-6t compatibility? - 10.04.2009, 03:23 AM
hey there guys
i was wondering if the mud guards (eo414b/c) from a mbx6t can be used on a mbx5t? or are the rear lower arms compatible between the two?
associated rc8t..........e
tamiya f104pro,r,w.f103gt.tb02,ta02
nuova faor sf501
avatar is pic of what our cat does with empty boxes left over from rc purchases
wallot
wallot's Avatar
10.04.2009, 04:08 AM
mudguards - yes, however :)
first and last hole is direct fit. you will have to redrill two midlle ones and use lock nut to secure the mud guard.
http://img.rcx.cz/nm2.jpg
i use mbx6 mud guards on my mugen as they are much taller in front
arms. they should however it I would go for complete (lower/upper arm) swap as the geometry is different.
also at least on mbx6 buggy the arm material is different from mbx5 and does break more easily.
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
kneedeeppow
10.14.2009, 03:30 AM
are the hinge pins from a mbx6t compatible with a 5t?
nuova faor sf501
