Flux Eagle Tree Data 4s 6000mah 20C
TLTRyan
Flux Eagle Tree Data 4s 6000mah 20C - 10.28.2009, 07:07 PM
HPI is not lying when they say you need batteries that are capable of handling 120A continuous.
This was my first run. It was all off road. You can see I started off the run rather slow to get the feel for the truck. After a few minutes I got used to WOT and used it quite often..
The BLUE Line is Voltage and the PURPLE line is Amps
This is the entire run.
The next 2 graphs are zoomed in and show a few seconds of the run in detail. My voltage drops are about 1V under a 120A load.
My run was stopped short from loosing a wheel. The logger said I used 4600, I recharged about 4300.
JThiessen
JThiessen's Avatar
10.28.2009, 08:51 PM
Looks like you were running 4S batt's. What is your brake and drag brake setting? Your braking/off throttle amp peaks are higher than what I would have guessed - but I have only a browsing experience with the logger data...
TLTRyan
10.29.2009, 06:27 PM
Drag brakes are off. Brakes are at 50%.
naynay12
10.31.2009, 06:11 AM
geez i just bought a turnigy 5s 500mah 20z pack for my savage conversion,and will be running hpi 2200kv with ezrun 150a esc.any suggestions how to keep it from over heating/frying the esc,such as changing esc settings?
fastbaja5b
fastbaja5b's Avatar
10.28.2009, 09:50 PM
Amp spikes look consistant with when I did the same sort of graphing on 4s Lipo on the Flux
Say Less, Do More.
