i am looking into converting my TTR ER-1[1/8 scale TC] from nitro> BL
but i amnt sure on what system to get i had been looking at the speedpassion silverarrow ESC/3.5motor but that was till i noticed it was sensored setup, and have noticed the sensored motors are a bit more pricey compared to unsensored motors
i have had a look at geting the castle MMM but am now having trouble on finding unsensored motors of about 4500kv > 6000kv
if anyone can advise me on wich ESC/motor to use as i am new to the electric side of things and since BL seems to be a lot more reliable and faster than nitro
Why do you need such a high kv motor for? General rule of thumb is you want the brushless motor to spin about the same speed as the nitro motor that came out of it. I don't know the setup on the car you mentioned but I'm sure it's similar to most 1/8 vehicles. Your going to want to run at least 4s if not higher for efficiency. At 4s something in the 2000-2200kv range is generally used, 5s 1600-2000kv, 6s 1300-1800kv. A 4500-6000kv motor in a 1/8 would need to be geared with about a 5-6 tooth pinion to be useable without pulling enormous amps on start up
i had been advised to use a higher kv motor as its for a TC/onroad RC. and with the higher kv i could use a 2S or 3S lipo to save a bit more weight. if i was to run a high kv motor i guess i would need a lipo with a very high C rating then ?
the nitro egine that came out was a thundertiger pro .28BXr max RPM of about 35,000. i was also running a 13t/15t and once a 18t clutchbell
The SpeedPassion 1/8th Silver Arrow ESC has gotten quite a few bad reviews from what I've read. Lots of "Blew up on the first run" situations. Supposedly a V2 is going to be (or has been) released that fixes the issues, but I haven't really followed them at all.
Stick with a MMM or Tekin system and you can't really go wrong.
