e-revo chassis
medicineman
medicineman's Avatar
Unhappy e-revo chassis - 05.17.2010, 08:37 PM
I am tryign to find an after marcket E-rvo chassis i have tryed the Kersaw chassis and all it did was bend and the stock chassis i have also heard about a G3R chassis but i can't find one any where is there any other chassis i could try?
I was also thinking about trying to run a vantage CF chassis but i wasn't sure what battery boxes would work?
  Send a message via Yahoo to medicineman
sikeston34m
sikeston34m's Avatar
05.17.2010, 08:45 PM
The Gorillamax G4! I've been tempted to get one of these for awhile now.
Check it out.
http://www.rc-monster.com/gorillamaxx.php
revo guy
05.17.2010, 08:51 PM
Sadly that G4 is for a tmaxx, there is not a gorillamax chassis being made for the revo right now
Chadworkz
UE Supermaxx Addict!
Chadworkz's Avatar
05.17.2010, 08:53 PM
The G2R and G3R are made specifically for the Revo, they are just hard to find...and if you do find one, it is crazy-expensive!
-Chad
PM ME IF YOU HAVE THE BELOW:
sikeston34m
05.17.2010, 09:13 PM
Ooops Sorry. My bad.
Chadworkz
Chadworkz's Avatar
I run a Nitro Revo 3.3 with Vantage Carbon-Fiber chassis converted to brushless using Mike's RCM motor-mount and the stock nitro transmission locked into 2nd gear with all of the 1st gear parts removed. I custom-built a carbon-fiber battery-tray that mounts on the right side of the truck in the exact same place that the Tekno RC battery-tray mounts when using the Tekno BL conversion. I also custom-made carbon-fiber ESC tray, Receiver tray, motor-mount brace, motor-mount support, and accessory tray (nothing mounted on it yet).
With the motor on one side and the battery on the other side, the truck is perfectly balanced, handles beautifully, and is uber-durable!
-Chad
Chadworkz
Chadworkz's Avatar
05.17.2010, 08:56 PM
SOme pics...
-Chad
revo guy
"The G2R and G3R are made specifically for the Revo, they are just hard to find...and if you do find one, it is crazy-expensive! "
Yep, that is what I ment lol, There used to be but they are no longer being made
Chadworkz
Chadworkz's Avatar
-Chad
Chadworkz
Chadworkz's Avatar
05.17.2010, 09:01 PM
And [here] are some pics with the body on...
-Chad
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
05.17.2010, 09:07 PM
Whats with all the zipties on the motor?
Chadworkz
Chadworkz's Avatar
05.17.2010, 09:50 PM
I had an incident when I first built the truck where I didn't set the pinion back far enough and when the motor spooled up, there was just enough rotor-float to allow the pinion to come forward enough to get into the slipper, which torqued the motor forward and to the side, bending the RCM motor-mount (which Mike replaced for free, by the way). I now use zip-ties to hold the motor tightly against the rear cradle and brace.
-Chad
Muggydude
05.17.2010, 09:27 PM
yo chad, would you consider making another esc mount like the one you have there and sell them to me? It would really help me with my build. LMK
Also, what brand pinion is that?
Chadworkz
Chadworkz's Avatar
05.17.2010, 09:55 PM
Sure! The pinion is actually a crappy Novak pinion. I usually run Mike's RCM pinions, but I had to switch spur-gears and the only pinion I had that was the right size for the new spur was one of my old Novak pinions. trust me, don't buy Novak pinions, they are horrible...they are not truly round, the teeth are not profiled correctly, they are cast instead of machined.
-Chad
medicineman
05.17.2010, 09:48 PM
I am deployed at the moment so trying to build anything out of CF on my own is out for the next 12-14 months i was hoping that there was one i could buy. I guess i will try the push rod mod i seen on mister crash's thread and see where that gets me
