Best plugs? -
06.03.2010, 02:35 PM
Hello,
I'm upgrading from two 2S Lipos (puffed) to a single 5S pack, and as I was ready to solder the plug (was using Traxxas as it was more convenient in the past), I realize that the big 8awg wires of the 5S lipo won't even fit inside the smallish Traxxas plug.
What are you guys using?
Thanks
Loa
Guelph, Canada, eh!
06.03.2010, 02:38 PM
5.5 mm Polymax bullet connectors. I used EC style connectors and Deans before and then went to bullets and never looked back. Some like to use even bigger bullets like 6 or 6.5 mm.
06.03.2010, 02:47 PM
Thx mistercrash.
How do you keep the bullets from touching each other (+ and - I mean)?
Loa
06.03.2010, 03:02 PM
Originally Posted by loa
Thx mistercrash.
Loa
I use 5.5mm bullets on everything. But I will be upgrading to 6.5mm on a project car.
I use all females on the motor side of the bullets, and all males on the ESC.
As far as batteries, I run the positive(+) side of the battery with females and the negative(-) side of the battery with males. Then on the ESC positive(+) battery lead i run a male and on the negative (-) I run a female. I have yet to have a problem with anything yet.
06.03.2010, 03:10 PM
+1 I'm using Neu 6mm bullets now on my batteries and escs
06.03.2010, 02:48 PM
i just use my 80w soldering iron and extra flux to get 8awg onto deans plugs. the flux makes it so much easier.
06.03.2010, 03:13 PM
Hello,
What I meant with keeping the bullets apart is this: bullets are kind of naked or exposed. The battery runs a great risk of shorting itself if all you have on the end of the wires are bullets.
Do you simply use shrink tubing up the the end of the bullets?
Loa
06.03.2010, 03:39 PM
Hello,
Loa
Use shrink tubing but also stagger your wires by about an inch
06.03.2010, 04:13 PM
Thx! Will do!
Loa
06.03.2010, 03:18 PM
Honestly, I haven't found anything better than Deans. I'll grant anything over 10 gauge might not be easy to solder, but i have never wore our any that i have used. They get a little black spot on them, I use an abrasive ink eraser to clean them
Fat Kid Engineering
06.03.2010, 04:30 PM
06.03.2010, 07:37 PM
Originally Posted by Bondonutz
I just used my "bonus bucks" there to buy 20 sets of EC5's. Converted everything over last night from Deans. 4 esc's, 8 lipo's, and the charger. REALLY easy, and I'd have to say they should be capable of the same amperage as Deans, if not better. Not sure how they compare to bullet connectors for amp flow.
06.09.2010, 08:21 PM
EC5s is what I use, can be a pain to take apart if you ever need to though.
07.17.2011, 10:08 PM
ProMatch sells EC5 connectors for $2/pair or $1 for either female or male. The females are all the same but the ProMatch males are sping type bullets like the Castle's and are much better than the HK ones. Owning both, I use the HK makes only for the chargers and the ProMatch males on my ESCs where the current can get really high.
Admitedly the ProMatch are about twice the cost of the HK part, but considering how many you are likely to need, I think the additional dollar is well worth it.
06.09.2010, 08:26 PM
Went with 6.5mm bullets from Castle I had lying around, separated by shrink tubing and glorious duct tape!
:-D
Loa
