esc capacitor Q:
mamba max1
mamba max1's Avatar
esc capacitor Q: - 06.21.2010, 11:09 PM
I'd like to get a capacitor for my MMM, but Mike is out of them.
Would something like this work:
http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWAX:IT
If not, what would I be looking for?
Thanks.
simplechamp
simplechamp's Avatar
06.22.2010, 09:04 AM
I just search Ebay for "low ESR capacitor" and always find what I need. It is important that they are low ESR and that you use short leads when connecting to keep overall resistance low. Look for caps rated to 105C temps, most low ESR caps will be.
Also a good rule of thumb is to get caps rated for an extra 50-75% of the voltage you plan to run. 35V caps are pretty well accepted for up to 6S. Running caps at their max rated voltage will greatly reduce lifespan of the cap.
Finally, running two 1000uF caps in parallel is better for dissipating heat than one single 2000uF cap, so if you have room look at making a bank of smaller caps instead of one big one.
nitrostarter
nitrostarter's Avatar
06.22.2010, 10:56 AM
Have a look:
http://www.offshoreelectrics.com/pro...035-lv&cat=136
N. Rustler conversion
simplechamp
06.22.2010, 11:23 AM
What is the capacitance of that bank, can't find it.
snellemin
2 KiloWatt RACER
snellemin's Avatar
06.22.2010, 12:15 PM
That bank has 8 caps of 470uF ea.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
simplechamp
06.22.2010, 12:26 PM
I'll take your word on the 470uF, but the pic shows 10 caps.
snellemin
2 KiloWatt RACER
snellemin's Avatar
06.22.2010, 01:26 PM
I can't count
mamba max1
mamba max1's Avatar
06.22.2010, 02:43 PM
Thanks! So then, would the desired ESR be about 2000 if I'm running 6s?
Edit: So these are what I'm looking for to run two in parallel:
nitrostarter
06.22.2010, 12:34 PM
It is 10 caps. I have one on my MMM going in my On-road speed car to help with spikes on braking.
simplechamp
06.22.2010, 04:08 PM
Well, two of those in parallel would be 2000uF, but that is the capacitance. ESR stands for equivalent series resistance, as long as the cap is listed as low ESR you aren't as concerned with the exact ESR value.
I would run 3 of those for 3000uF. That is the guy I usually buy caps from, good guy to deal with.
mamba max1
mamba max1's Avatar
06.22.2010, 05:13 PM
Sweet. I had to look through all 11 pages on ebay to find them.
Big thanks for the help!
phildogg
phildogg's Avatar
06.22.2010, 07:18 PM
I've also bought from him. good guy..
phil
Slash 4x4 163mph
drc rail 150 mph
phildogg6@yahoo.com
my youtube channel
