Fat Kid Engineering
Has anyone tried these yet ? -
07.01.2010, 03:20 PM
Soldermaster Extraordinaire
07.01.2010, 06:15 PM
Woah a 700XXL! That's a shaft-snapper for sure.
Based on the price alone I would put them between Feigao and Align quality wise. Would you like to be the guinea pig on this one, Bondo?
07.01.2010, 06:18 PM
they look like Neu 1521 and 1527 knock-offs....
Fat Kid Engineering
07.01.2010, 06:28 PM
YUP, A BIG Guinea Pig.
I dont have miuch faith in the qaulity but again for the price it's certainly worth a risk I reckon ? I ben needing another 1527 w/a lower KV but no one has stepped up to the plate and can't buy from NEU on such short notice. So I guess my 1527 1.5D will go in my TRX Titan boat when it arrives ????
Once my check hits my account tonight I'll be ordering the 700-83 in 975KV for my 1/5 Savage build. Still not for sure what Controller I'm using but I'm planning on 8s and 10s for sure !
I'm making my own chassis (started today)and will have plenty of room for Lipos up front and will make my own center shafts.
Still waiting on my F#*kin' Dirt Oval car from Horizon so I figured might as well to working on sumthin' else ?
07.01.2010, 10:06 PM
No worries... The seller is still jerking me around on my GTP roller. I have a Paypal dispute open on him right now....
Fat Kid Engineering
07.01.2010, 10:09 PM
OUCH, Good luck getting your item.
Sorry to complain.
Fat Kid Engineering
07.01.2010, 07:01 PM
This may be a stupid question ?
Will MIKES 1/5 scale Mod-1.5 pinions work with Mod-1 spurs without making a bunch of noise and mesh decently ?
Anybody know ???????
I ask because I want the larger 98mm motor but it's availibe in 8mm shaft only, SHIZ !
07.01.2010, 07:02 PM
Mod 1.5 has a much larger tooth than Mod 1. I don't think it will mesh at all. That's like trying to mesh 32P to 48P.
Fat Kid Engineering
07.01.2010, 07:04 PM
Mod1 and 32 pitch kind work together but make a racket, thought I might get lucky since the spur is so thin ?
07.01.2010, 07:06 PM
Well 32P is technically Mod 0.8. I wouldn't risk it with the power you'll be putting down through that motor.
Fat Kid Engineering
07.01.2010, 07:16 PM
Yeah I know, just hopeing for a easy way out. Aint gonna happen, such as my luck.
07.01.2010, 07:36 PM
maybe you could grind the shaft down to 5mm yourself. i have done it with a 6mm KB motor shaft and if i can do it, you can do it. all i used was a dremel against the shaft while it was spinning.
Fat Kid Engineering
07.01.2010, 08:01 PM
I tried that when I got my 1717, I chucked the rotor in a drill press on low rpm and used high qauilty metal file w/oil bath. It worked but I wasn't real happy w/the end result.
I do however like your idea, might be a little easier to knock the material off ?
Did you just use a sanding drum ??
07.01.2010, 07:56 PM
I have a brand new 1521 1.5y (1050kv) w/5mm shaft if you're interested in trying something a little smaller than the 1527 (cheaper than OSE's price). I was going to try it in my build but went with the 1527 instead.
Fat Kid Engineering
07.01.2010, 08:04 PM
I appreciate that, I'll keep it in mind.
PM me with what your looking to get out of it.
Thanx
