Thread Tools Rating: Thread Rating: 2 votes, 1.00 average. Display Modes
Best dry lube for CVD
mothman
Best dry lube for CVD - 02.20.2011, 12:35 AM
been reading about dry lube that people applied on the CVDs. Pedros ice wax, extra dry, dow 557, white lightning.. do you guys know what is the best for the drive train parts like CVDs/dogbone?
Shimmy
04.18.2011, 06:04 AM
Late reply but...
I found this while looking around the other day...
http://thinkomnimedia.com/pages/howt...owto=26&page=6
http://www.carchemistry.com/shop/ind...t_detail&p=177
04.18.2011, 07:29 AM
giggity
mothman
04.18.2011, 01:47 PM
Originally Posted by Shimmy View Post
Hey shimmy, thanks for the input. Have you tired this lubricant? I have read somewhere about this but not sure how good it is..
Shimmy
04.18.2011, 02:03 PM
No worries.
Nah, I havn't tried it mate, been thinking about grabbing a bottle of it though.
Was thinking that if it bonds to the surface, it could be waterproof, that would be handy aswell, but I am not completely sure if it is.
mistercrash
Guelph, Canada, eh!
mistercrash's Avatar
04.18.2011, 08:20 PM
candle wax
No brain, no headaches.
mistercrash
Guelph, Canada, eh!
04.19.2011, 11:07 AM
Ok I'm not kidding about candle wax. Old folks used to rub candles on wooden drawers to make them slide easier. It works as I've done it many times on old wood furniture. So I thought of trying it on axles one day. I light a candle and let a few drops of melted wax fall on the axle's joint. Then I heated the joint with a heat gun to make the wax spread uniformly over all the parts and flung off the excess. Once it cools off, every part of the axle joint is covered by a thin film of candle wax which does not attract dirt and dust and protects very well against rust.
josh9mille
josh9mille's Avatar
04.18.2011, 10:27 AM
Skip the dry lube and go directly for the KY Silicone lube, its much better than the water based stuff
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
04.18.2011, 12:30 PM
If KY works better than your putting your gears in the wrong place ?
Tags
cvd, dry lube
