Gearing for a 1900kv motor.
speedy
Gearing for a 1900kv motor. - 04.03.2011, 07:33 AM
Hi !
I have an e-maxx bl ed with a 1900kv motor in 1515 size runing 4s lipo! What gearing would be good for this setup for offroad use?
04.04.2011, 05:01 PM
What esc are you using?
What motor is it exactly?
I would say though that with the BL Emaxx's 6.3" tires ( I assume you are using those ), something like 20-22/68 gearing will be fine for ~40mph topspeed- adjust gearing up or down depending on motor/esc & battery temps ( hot motor + cool esc = gear up, cool motor + hot esc = gear down, hot everything = gear down ).
speedy
04.04.2011, 05:43 PM
I,m using this combo http://shop.lindinger.at/product_inf...ducts_id=80585
04.05.2011, 09:23 AM
Originally Posted by speedy View Post
Looks like a dodgy copy of the castle MMM system- even the esc case and layout looks nearly identical. I too would default all the settings, adjust your lvc for 3.2-3.4v per cell ( if possible ), then take it from there....
x-y
x-y's Avatar
04.05.2011, 08:48 AM
I recommend you buy many pinions and make tests of temperature ........... ¿you use mod1 or 32p?
SWORKZ BE-1, LEOPARD, HOBBYWING, GENS ACE, SANWA VX, FUTABA 3PL, MBX5R/T, RB5SPSL, FG MONSTER, TC5R, 808E, HYPER8, TF5, ZX5, NANO-TECH, HYPERION, 620DMG, ECO6-10, TEAM-IHOBBIES
speedy
04.05.2011, 03:29 PM
I found the problem :)
It was the throtle expo setting that made the motor act funny !
On this esc i can only activate the "auto detect" or nicd/nimh mode...
I have the mmm combo that came with the truck but i don'whant to use it now when it's springtime and extreamly wet outside.
I,ve waterproofed the anaconda esc.
