Brushless swap problem
T-birdJunkie
Brushless swap problem - 06.10.2011, 02:52 AM
So, for years, I've been running brushed in my 2wd buggies. I've been running pretty much nothing but 14x2 motors, and having no issues keeping up even with the 7.5s and 8.5s at the track. Car runs cool, runs fast, and needs a comm cut maybe every 10 to 14 race days with a cleaning here and there and the occasional brush swap. It's been dead nuts reliable.
Until now.
Dropped a Tekin 13.5 into it that I got from a buddy, and as soon as the car was plugged in, it basically went FIZZZZZZZZZZ *smoke*. The motor only had 3 runs on it when it was put into the B4.1 FT in question, and it ran perfect when it was pulled from a buddy's RB5.
Any ideas on what may have happened? Here are before swap and after swap pics. Hopefully you see something I don't.
Team Pie 420
The Dude
06.10.2011, 03:08 AM
Looks like your using a brushed ESC to try and drive the brushless motor.
You need an ESC that's designed for brushless systems.
06.10.2011, 03:47 AM
thats just all wrong, is this for real?
crazyjr
crazyjr's Avatar
06.10.2011, 05:07 AM
If this is the same T-birdjunkie on rc tech forum, it's got to be a prank. With 22 posts, in the best place for brushless, you asked the wrong questions
BIG-block
06.10.2011, 05:25 AM
No way this guy is serious. Anyone that has walked past a RC race track will know that you can't run a brushless motor with a brushed speedie. Prankster for sure.
crazyjr
crazyjr's Avatar
06.11.2011, 08:50 PM
I wasn't, you missed this on page 1.
Only reason, I said what I said on page 2, was if for some reason you weren't who i thought and really did something stupid. One problem with the pics , no blackening due to the proposed cookout
brian015
brian015's Avatar
06.10.2011, 06:32 AM
Dude, I'm not quite sure what you're talking about here, but I think you need a new barber. I didn't know what a "comm cut" was, so I googled it and came up with this guy:
If this is you, then you definitely need to make a change - tell your barber you no longer want the "comm cut" and go for something else. And he's ripping you off if you have to go back every 2 weeks for a new cut.
Another thing, when you say "a cleaning here and there" - the way most of us clean our hair is when we take a shower, is that what you're talking about?
And the "occasional brush swap" - I'm not sure it this is coded language for something kinky or not, but I'll tell you that I've had the same hairbrush for the last twenty years or so - I think it's made of genuine horsehair - but let me say that you get what you pay for - so you need to invest in something that will last.
Anyway, I hope this helps.
pinkpanda3310
pinkpanda3310's Avatar
06.10.2011, 08:55 AM
You made it go POOF but you could've made it go faster by using 6s
bruce750i
bruce750i's Avatar
Wink 06.10.2011, 11:22 AM
Bruce750i says too high of C rating blows them every time.
brainanator
brainanator's Avatar
06.10.2011, 12:01 PM
Probably the headlight fluid. Either that, or double check the muffler bearings, ever time they make one revolution 1 ounce of grease should drip on the floor. Any less than that and they need a refill too.
T-birdJunkie
06.10.2011, 12:17 PM
I appreciate you guys' sense of humor, but this isn't helping me resolve my problem. Is the root cause of this problem being that you can only run Novak speed controls with Novak motors?
Back when I got the speedo Novak specifically told me that it would run ANY motor I wanted as long as I was running less than 8 cells NiCd. Obviously we're two battery chemistries away from NiCd, but the input voltage is still far lower.
brainanator
06.10.2011, 12:29 PM
in that case then it sounds like a warranty issue. Better call the motor and ESC manufacturer and explain exactly what is going on. I'm sure they will just hand the company over to you.
T-birdJunkie
06.10.2011, 12:37 PM
The ESC is 12 years old, I'm pretty sure there's no warranty on it
brainanator
06.10.2011, 12:51 PM
what kind of CRAP manufacture is that?! not offering a 12 year warranty?! That's bullcrap!
bruce750i
bruce750i's Avatar
06.10.2011, 01:13 PM
Where did you get info on how to wire the brushless motor in?
